No, this is stored as normal text string, machine won't interpret it...oscilloscope wrote: 21 Aug 2022, 15:24 How is one ment to over write the entry if its already been converted to machine language. ?
Just search and replace...
Does anyone have schematic for the pins?T5Luke wrote: 21 Aug 2022, 03:29 Here have fun with it:
Code: Select all
#define BKPT 4 #define RESET 5 #define FREEZE 6 #define DSI 7 #define DSO 8 static word CMD_READ = 0x1940; static word CMD_GO = 0x0C00; static word CMD_WRITEM = 0x1840; char command; int n_line; void setup() { // put your setup code here, to run once: pinMode(BKPT, OUTPUT); digitalWrite(BKPT, HIGH); pinMode(RESET, OUTPUT); digitalWrite(RESET, LOW); pinMode(FREEZE, INPUT); pinMode(DSI, OUTPUT); digitalWrite(DSI, LOW); pinMode(DSO, INPUT); Serial.begin(57600); while(!Serial){ } Serial.println(F("Arduino CEM Reader, press:")); Serial.println(); Serial.println(F("e: enter BDM Mode")); Serial.println(F("l: leave BDM (experimental)")); Serial.println(F("r: read complete memory")); Serial.println(F("b: read Boot 0-3FFF")); Serial.println(F("s: read security block 4000-7FFF")); Serial.println(F("d: read car data 8000-1FFFF")); Serial.println(F("f: read firmware 20000-7FFFF")); Serial.println(F("c: BD32 Command Mode")); } void loop() { // put your main code here, to run repeatedly: if (Serial.available()) { command = Serial.read(); switch (command) { case 'e': Serial.println("Enter BDM"); digitalWrite(BKPT, LOW); delay(10); digitalWrite(RESET, HIGH); delay(100); Serial.println(digitalRead(FREEZE)); break; case 'l': Serial.println("leave BDM"); shift_BKPT_up(); digitalWrite(RESET, LOW); delay(10); digitalWrite(RESET, HIGH); wait_openchannel(); bdm_command(CMD_GO); digitalWrite(DSO, LOW); shift_BKPT_up(); Serial.println(digitalRead(FREEZE)); break; case 'r': Serial.println("Read FLASH"); for (unsigned long offset = 0x0000; offset<=0x7FFFF; offset = offset + 0x02) { shiftRWord(offset); } break; case 'b': Serial.println(F("Read bootblock")); for (unsigned long offset = 0x0000; offset<=0x3FFF; offset = offset + 0x02) { shiftRWord(offset); } break; case 's': Serial.println(F("Read securityblock")); for (unsigned long offset = 0x4000; offset<=0x7FFF; offset = offset + 0x02) { shiftRWord(offset); } break; case 'd': Serial.println(F("Read cardata")); for (unsigned long offset = 0x8000; offset<=0x1FFFF; offset = offset + 0x02) { shiftRWord(offset); } break; case 'f': Serial.println(F("Read firmware")); for (unsigned long offset = 0x10000; offset<=0x7FFFF; offset = offset + 0x02) { shiftRWord(offset); } break; case 'c': Serial.println(F("BD32 Command Mode")); serialFlush(); while(!Serial.available()); { } break; default: break; case 'i': Serial.println("wipe"); for (int i=0; i<=250; i++) { digitalWrite(BKPT, LOW); delay(1); digitalWrite(BKPT, HIGH); delay(1); } break; } } } void shiftRWord(unsigned long val) { word i; word lowbyte = val; word hibyte = val >> 16; //Wait for DSO to get 0 => gets ready wait_openchannel(); bdm_command(CMD_READ); shift_BKPT_up(); shift_BKPT_up(); for (i = 0; i < 16; i++) { //HighByte digitalWrite(DSI, !!(hibyte & (1 << (15 - i)))); shift_BKPT_up(); } digitalWrite(DSI, LOW); delayMicroseconds(1); shift_BKPT_up(); for (i = 0; i < 16; i++) { //LowByte digitalWrite(DSI, !!(lowbyte & (1 << (15 - i)))); shift_BKPT_up(); } digitalWrite(DSI, LOW); delayMicroseconds(1); word W_Read; for (i= 0; i < 1; i++) //Read Status Byte { //digitalWrite(BKPT, HIGH); //delayMicroseconds(1); digitalWrite(BKPT, LOW); delayMicroseconds(1); //Serial.print(digitalRead(DSO)); } for (i= 0; i < 16; i++) //Read back { digitalWrite(BKPT, HIGH); delayMicroseconds(1); digitalWrite(BKPT, LOW); delayMicroseconds(1); //Serial.print(digitalRead(DSO)); bitWrite(W_Read,(15-i),digitalRead(DSO)); } check_lzero(W_Read); if (n_line <=6) { Serial.print(W_Read,HEX); Serial. print(" "); n_line++; }else{ Serial.println(W_Read,HEX); n_line = 0; } //return W_Read; } void write_Register(word cmd, unsigned long addr) { word lowbyte = addr; word hibyte = addr >> 16; wait_openchannel(); //Wait for DSO to get 0 => gets ready bdm_command2(cmd); shift_BKPT_up(); for (int i = 0; i < 16; i++) { //HighByte OFFSET digitalWrite(DSI, !!(hibyte & (1 << (15 - i)))); shift_BKPT_up(); } digitalWrite(DSI, LOW); delayMicroseconds(1); shift_BKPT_up(); for (int i = 0; i < 16; i++) { //LowByte OFFSET digitalWrite(DSI, !!(lowbyte & (1 << (15 - i)))); shift_BKPT_up(); } digitalWrite(DSI, LOW); delayMicroseconds(1); } void check_lzero(word W_Read){ if (W_Read < 0x10) { Serial.print("000"); return; } if (W_Read < 0x100) { Serial.print("00"); return; } if (W_Read < 0x1000) { Serial.print("0"); return; } } void shift_BKPT_up() { digitalWrite(BKPT, LOW); delayMicroseconds(1); digitalWrite(BKPT, HIGH); delayMicroseconds(1); } void wait_openchannel() { while(digitalRead(DSO)!=0) { shift_BKPT_up(); } while(digitalRead(DSO)!=1) { shift_BKPT_up(); } } void bdm_command(word command) { for (int i = 0; i < 15; i++) { digitalWrite(DSI, !!(command & (1 << (15 - i)))); shift_BKPT_up(); } digitalWrite(DSI, LOW); } void bdm_command2(word command) { for (int i = 0; i < 16; i++) { digitalWrite(DSI, !!(command & (1 << (15 - i)))); shift_BKPT_up(); } digitalWrite(DSI, LOW); } void serialFlush(){ while(Serial.available() > 0) { char t = Serial.read(); } }
SMOK UHDS works easily.duzi wrote: 21 Aug 2022, 23:46 it seems that the "SMOK UHDS" gentleman also reads this branch. L (H) cem pin reading added in new update,True, with the year 2002 he was mistaken..Guys you make the world a better place t.y
I was talking to the dev at SMOK and I wanted to know if the 0012 add on works on bench. As it can read all sorts of ecus. Sid807evo , Edc16c34 , newer cems to copy the info for cloning , which might be handy for pin reading.urosm wrote: 24 Aug 2022, 01:30SMOK UHDS works easily.duzi wrote: 21 Aug 2022, 23:46 it seems that the "SMOK UHDS" gentleman also reads this branch. L (H) cem pin reading added in new update,True, with the year 2002 he was mistaken..Guys you make the world a better place t.y
I tried last night to read the PIN from some CEM I have at service.
2 of 3 are read without problem on the bench. 1st is read in 10 minutes, the second one in 5 minutes.
The second one has a flash from 2012/2013 XC90.
From 3rd won't read PIN, but I think some corrupted flash written into it.
And the last one I tried in my 2008 XC90 thru OBD. In 5 minutes PIN was found.
Eh ? You don't need iot , you can use xprog , carprog , orange5 (not all mcu is covered) , etl iprog , vvdi things like that. , but if you mean for convince its not always easy. To just plug in and it makes it all happen. Is that what you mean?duzi wrote: 25 Aug 2022, 08:46 what's the point, of reading a pin if it doesn't read the flash or config...without ioterminal, still have to remove the module
The main point was I needed something to fight my boring job a few years ago, to do something fun and brain-involved.duzi wrote: 25 Aug 2022, 08:46 what's the point, of reading a pin if it doesn't read the flash or config...without ioterminal, still have to remove the module
