The fuel pump on my step daughter's 2000 V70XC has crapped out. Unfortunately we no longer live in the same state, so I've had her send her car to a local shop instead of doing the work myself. The shop reports that they can't source a new fuel pump assembly for this car, and it seems that FCP Euro has the part on indefinite backorder. https://www.fcpeuro.com/products/volvo- ... wd-9470674
Does anyone have a good source to get this fuel pump? The other alternative I can think of (since the sending unit is still functional), is to disassemble the fuel pump/sender assembly and replace just the electric pump by itself. If I go this route, is the pump available, and can anyone give me a confirmed brand/part number for the pump itself?
The rest of the car is in pretty good shape, and has served my step daughter quite well. I'd hate to get rid of it over a relatively minor issue.
Thanks in advance!
Fuel pump for 2000 V70XC 9470674
- Been thanked: 4063 times
The pump motor is a Walbro GRJ 235 and is also no longer available. Last seen in about 2020
There are afterMarket replacements at the usual suspect places. I’ve had to order 5 to get 2 working units
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Everybody's friend Robert just did an aftermarket pump on his T5R, don't know if this will help your remote situation.AKJeeper wrote: 24 Aug 2022, 15:57 The fuel pump on my step daughter's 2000 V70XC has crapped out. Unfortunately we no longer live in the same state, so I've had her send her car to a local shop instead of doing the work myself. The shop reports that they can't source a new fuel pump assembly for this car, and it seems that FCP Euro has the part on indefinite backorder. https://www.fcpeuro.com/products/volvo- ... wd-9470674
Thanks in advance!
- foggydogg
Rock Auto shows a couple,
https://www.rockauto.com/en/catalog/vol ... +pump,6256
Some folks have used Delphi before,
https://www.rockauto.com/en/moreinfo.ph ... 97&pt=6256
Assembly
https://www.rockauto.com/en/moreinfo.ph ... 47&jsn=457
And as usual, avoid everything and anything that starts with URO...
(Might be an Oops, I just noticed it's an XC, I had looked up one for my car...)
Assembly
- Has thanked: 2196 times
- Been thanked: 1850 times
V70 XC and R use the same pumps.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
You can try these guys..... supposed to be an official distributor.
https://walbrofuelpumps.com/
They have a listing for my 96.
Also https://www.highflowfuel.com/ has Walbro/TI kits that seem to be priced well.
I'm kinda looking a bit since I've noticed my car isn't wanting to start quite as easily after it sits for hours. I've done no trouble shooting yet, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
The first link does not include the AWD cars, only FWD.
From your 2nd link they have this listed:
https://www.highflowfuel.com/product-re ... 70~zp_2-4l
which would appear to be correct. My only comment is that they list it as fitting 1997-2007 cars. 1997-98 cars ran at a lower fuel pressure than 99- which may be an issue so anyone trying this may want to talk to them first to make sure this is correct.
Thanks,
Thanks,
The above link is a more expensive pump, about $110, but it’s actually a Walbro design
So abscate did you give up on the job lot you got? Did you go out and buy another?
Ebay guy sent me two replacements for the ones that were dead. I was $10 into them.scot850 wrote: 01 Sep 2022, 20:33 So abscate did you give up on the job lot you got? Did you go out and buy another?
The TI pumps above were more expensive but were assembled with the snout all good to go, no fitment issues. $110 but I’m sure feeling better about that with all that Labour
- 42 Replies
- 11999 Views
Last post by Maestrours
- 39 Replies
- 2791 Views
Last post by VolvoOwl98
- 151 Views
Last post by PatternFlyer
- 115 Replies
- 14764 Views
- 3024 Views
Last post by Larry_Dean
