More power out of b5254t(this has been done too many times I know) Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Goupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T :shock:
Overflowed the MAF, bent some rods, overflowed the injectors, started knocking again :lol:
When you say " super16T ", is that the set up with the 11 blade turbine ?
1999 V70 GLT
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Sveedy wrote: 25 Aug 2022, 14:25
Nope, that's why it took us (me and the tuner, aaron from Vast) and the engine by surprise.
It's an old stock aftermarket turbo, the CHRA has been replaced by a 300$ OE type one and the hot side is an angled flange from a volvo 13t (not even the bigger one).
Nothing in this was supposed to perform more than any oem 16T, yet it does :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Petskoi
Year and Model: 1997 V70 awd
Post by Petskoi »
Goupil wrote: 25 Aug 2022, 13:58
Petskoi wrote: 25 Aug 2022, 13:46
The bent rods might be indicating too much boost too low at the rev range. I remember something like it needs to be ~0.7 bars under 3k rpm. Take this with a grain of salt tho, its a "trust me bro" statement
the bent rods were from me not looking at the data, doing a pull for logs, ran out of MAF unexpectedly so it was running super lean :?
The second time it started knocking makes no sense, there isnt anything wrong in the datalog :roll: I'm replacing the knock sensors and installing an oil pressure gauge this time (+ some H beam rods and new bearings)
Nice😎
Petskoi
Post by Petskoi »
Goupil wrote: 25 Aug 2022, 14:43
Well it is true, that a 13t flows actually better than even a 15g. I was counting some hp numbers with different psi's using the compressor maps for 13t, 15g, 16t etc. Thought I was counting wrong, checked many times then gave up and used an online calculator and it gave me same numbers
Petskoi
Post by Petskoi »
I was just wondering is it safe to drive the car to the tuning shop, after installing bigger injectors, the new turbo and the japanifold? The stock tune should limit the boost so that it doesnt lean out right?
Goupil
Post by Goupil »
I would say it will probably run richer more than anything due to the bigger injectors. Is it a long drive? If you can, keep it out of boost as much as you can and it should be fine
Petskoi
Post by Petskoi »
Goupil wrote: 25 Aug 2022, 22:44 I would say it will probably run richer more than anything due to the bigger injectors. Is it a long drive? If you can, keep it out of boost as much as you can and it should be fine
Ya, thats what I thought(try to keep out of boost/running rich) well the drive is 60km so... 40 Miles? Give or take
