98 v70--- will these steelies fit?
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
Hi
I got steel wheels, but they are 25mm offset from a Volvo 940
I have a 1998 Volvo v70
I hear these are 40mm offset or 43mm offset.
Question, are the offset negative or positive?
Which way, from the centerline, is negative?
So, -43 mm is that toward the engine (inside) or toward the fender lip (outside)?
Basically can I put these steel wheels on my v70?
I'm thinking 20mm or 15mm universal spacers.
Will that work, and if not how can I make it work?
Thanks
Big Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
Has thanked: 2211 times
Been thanked: 1852 times
What it means is if you imagine a center line down the middle of the rim looking at it side on, how far from that center does the face of the rim sit where it touches the brake rotor. For our Volvos 0mm means the mounting face is in the middle of the rim, 20mm means it sits 20mm outward toward the outside of the rim. This means the rim moves 20mm further in from the fender lip. P80 Volvos typically have around 43mm from the center so they sit even further in. P2 Volvos typically have 49mm so they go even further in from the fender lip.
So if you want the steelies to sit in the same position as a typical P80 rim you would need a 23mm spacer to sit the rim in the same spot as your current rims.
At least from what I have found a 92 Volvo 940 has the same center bore of 65.1mm and lug bolt spacing of 5 x 108mm.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Between these 3 sites you should be able to get all your answers on tires and rims.
https://www.wheel-size.com/size/
https://www.willtheyfit.com/
https://tiresize.com/comparison/
surfbug1
Post by surfbug1 »
Ok cool. So sounds like with the proper spacers, they will fit.
So, need spacers (size to be determined)
And probably need new lug bolts or lug nuts? Will research this more, and may pull a wheel and try to fit one of the steelies and see what happens.
Question ...
On this website:. https://www.willtheyfit.com/
They talk about poke and inset. What's that?
and arch gap loss. (Is this the space between the top of the tire, and the start of the fender?)
What are those things?
Thanks
Al
Ping me!
:D
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
The issue is that the 940 is RWD, and the P80 is FWD. FWD cars typically mount their wheels much further towards the face of the rim. A 23mm spacer is a very thick spacer. You'd really need a spacer that actually bolts on, and then allows for the wheel to bolt to it. Finding on that would accommodate our lug bolts might be difficult. If it were me, I think I'd rather find rims that didn't require a thick spacer.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
surfbug1
Post by surfbug1 »
Ok I will search wheel spacers with bolts.
When I got these steelies, I didn't check the fwd and rwd stuff
The ad did say RWD , but I didn't see that until I was loading them up, and then saw the 25 stamped on the rim
Didn't think it would be that much work.
Anyone wanna trade RWD steelies for FWD steelies?
πŸ˜‰πŸ˜‰β˜ΊοΈβ˜ΊοΈπŸ”₯πŸ”₯
Ping me!
:D
454cid
Post by 454cid »
Now that I've slept, I realize what I wrote doesn't follow what you're describing. The RWD rim should already be out too far on the FWD car. Have you test fitted the new rims yet?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 116 times
Post by Goupil »
FWD wheels have the mounting face more towards the outside of the wheel than RWD, so RWD on a FWD volvo will stick out more
For reference, this is my V70 on ET30 6.5" wide 16" steelies with 205 55 tires. Just fits without rubbing on anything, but it's close.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
surfbug1
Post by surfbug1 »
454cid wrote: 27 Aug 2022, 11:15 Now that I've slept, I realize what I wrote doesn't follow what you're describing. The RWD rim should already be out too far on the FWD car. Have you test fitted the new rims yet?
Oh. Yeah I wasn't sure that's why I asked on here.
But no harm no foul, I didn't order anything yet.
No I didn't do a test for yet, but I can do that next week! Hopefully they will just make it, only one way to find out! Yay , hope it works!
Al
Ping me!
:D
surfbug1
Post by surfbug1 »
Goupil wrote: 28 Aug 2022, 04:40 FWD wheels have the mounting face more towards the outside of the wheel than RWD, so RWD on a FWD volvo will stick out more
HEY GOUPIL,
That's good news! So mayyyyybe .....
My ET 25 (you have ET 30s, so that stick OUT more, right?)
I need to learn how ET 25 and ET 30
or -ET25 or -ET30 references the centerline or the outer edge of the rim...or the inner edge of the rim.
I gotta learn this stuff. Any links to educate myself?
So GOUPIL, your tires/rims just barely fit at ET30, so I should have extra space at ET25 correct?
thanks again! This just might work LOL
Allen
Ping me!
:D
