So I have the 13g with a straight housing(if its the right word) and I have a 16t with an angled housing. What volvo model downpipe do I need to buy to make it work? In my understanding I should buy like a -99 t5 downpipe right? Or is it an easy job to modify the stock dp to work?
Otherwise the swap should be just bolt on with the same lines?
13g to 16t swap
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Angled DP would be the easiest and best option I think. If you are getting a new one anyways and already have the angled turbo.
850 T5-R '95 auto
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Not a lot of options with this. I wouldn't waste money on anything with the straight exhaust flange. As hausmeister says, you already have the angle set-up, so I'm sure you're going with that. I just went through this a little bit ago, but with a 15g. You used to be able to buy just a downpipe alone from OBX but I couldn't find a source for them anymore. Then there are a couple of way expensive turbo back exhaust systems out there. I ended up having to bite the bullet and buy an IPD system which came with a 3" angled downpipe. Unfortunately I think they just had a price increase on their system.
1999 V70 GLT
1999 V70 GLT
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
TME (sweden) makes an AWD downpipe, it's good stuff but it aint cheap
http://www.tme.se/e_index.htm
Wasnt able to find an european shop with a listing
https://www.vivaperformance.com/tme-per ... 1999-2000/
A stock angled downpipe would be the 2nd best solution.
The 16T should bolt fine, if it's from a 99+ you might have to play with the coolant ports plug (-98 have IN on the engine side, OUT on the firewall while 99+ have both on the firewall side. Any turbo should have 3 ports with one plugged)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
gizmaster_1
- Year and Model: 850 Turbo 1995
- Has thanked: 5 times
- Been thanked: 3 times
Hi there, I came across this post so I thought I would try my luck
I'm thinking of swapping my factory 13g turbo to a 16T and I have a few questions.
1. Can I just buy a 16T compressor/housing and use it on the factory turbo? Will it give me the same improvement as installing a complete 16T?
2. Can I do a straight swap or will modifications be needed?
3. I bought the IPD Boost Control valve but didn't notice any difference, is a special set up required?
4. Should I get a manual boost control valve?
Thank you in advance
Luis
Luis
- Sveedy
1. I don't really understand this question. Are you asking about switching the internals of the turbo ? In any case, what you want is a complete 16T. Keep in mind that you need to have a different tune in the ECU for you to notice any difference between the two turbos.
2. They bolt up the same way, so no mods required.
3. I have heard nothing but bad regarding the IPD boost control valve. Pierburg is a better choice. Might be originally for a Porsche.
Not sure, so check, but #99660 or # 515500 is in my notes.
4. If you like. There is a link here on the site on how to make one.
1999 V70 GLT
1999 V70 GLT
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
Did it myself a few months back.gizmaster_1 wrote: 26 Feb 2024, 16:15 Hi there, I came across this post so I thought I would try my luck
Luis
1. Absolutely not
2. Make sure it is a -01 16T and it should bolt on fine (except exhaust, which needs an angle flange downpipe. If FWD, get the OBX system off eBay. If AWD, you're SOL and should find a 15G instead so it'll bolt on unless you're really handy with a welder, since nobody makes AWD downpipes)
3. IPD boost valve is absolute trash, get rid of it and put the stock one back.
4. No, you shouldn't. You'll break something in short order
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
gizmaster_1
Thank you so much for the info. I believe my car is a straight flange not an able one, can I still use the 16T turbo with a straight flange?
- Sveedy
My understanding is that you can use the straight flange, but the angled has better flow.
And I believe Vast Tuning also sells downpipes.
1999 V70 GLT
1999 V70 GLT
- 857 Views
Last post by Matt88ch
- 10 Replies
- 4438 Views
Last post by FLXC90
- 1006 Views
Last post by bmdubya1198
- 3035 Views
Last post by IG-88A
- 18 Replies
- 9524 Views
Last post by Vazfx16
