Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Shimmed my block, might just be placebo but it was just 5 bucks worth of metal
And made a power loom for my oil pressure gauge that plugs into the accessories connector
Getting another package delivered tomorrow, I should be able to start putting things back together
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Been thanked: 4068 times
3 hours and got the top of Elizabeth’s motor. Life is good
Lots of bent valves.
Celebrated by going to see Brandi Carlisle and Indigo Girls at Tanglewood.
Brandi was excellent, beautiful range and also wonderful three part harmony
Has thanked: 2202 times
Been thanked: 1852 times
Wow, you believe in really breaking it! Were you pulling 10,000RPM by any chance??
Goupil
Post by Goupil »
Go big or go home
Went big and needed a tow truck to go home :mrgreen:
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
spent a few hours at my mechanics helping around while getting a seized rear engine pad replaced on the v70. Picked some parts from a car they are going to scrap and hoping to get the front done in the morning.
2008 S60 2.5T Auto (Sold)
yanga001
Post by yanga001 »
changed the front and rear mounts, still have a vibration and it does not look like the exhaust. Since both mounts were shot i am wondering if it caused the side mount to fail early.
On a FWD you have really only 3 mounts. Front and rear cone mounts (hydraulic oil filled) and the pad under the crank pulley. Easy to tell on that one. Put a piece of wood under the oil pan near the crank pulley and jack it slowly and see if the metal bracket and rubber separate.
Only other 2 are the upper and lower torque rods.
yanga001
Post by yanga001 »
scot850 wrote: 01 Sep 2022, 17:24 On a FWD you have really only 3 mounts. Front and rear cone mounts (hydraulic oil filled) and the pad under the crank pulley. Easy to tell on that one. Put a piece of wood under the oil pan near the crank pulley and jack it slowly and see if the metal bracket and rubber separate.
I’ll check if it’s shot tomorrow and then order the part and change it on Tuesday. Car shifts smoother thanks to the changed hydraulic mounts. The old mounts were over a centimetre compressed when compared to the ones put in
Ah, they have lasted well! But even Volvo mounts don't last for ever.
I badly miss my wonderful p80 seats as my poor body suffers from this project….
Chairs for you , luggy! Drying off after an evening at Tanglewood
