Any thoughts on the reliability of tool such as this:pgill wrote: 30 Aug 2022, 18:18 XHEART,
The alternator drive pulley attached to the read will only move if you rotate the crankshaft.
So unlike the other side that is very easy to test by moving the belt at the AC compressor, the Alternator side doesn't have a simple test like that.
With the alternator removed from the engine it is easy to test but that is a lot of labor and if you find out that it is bad and then you need to replace the pulley and maybe you should replace the whole alternator or at least rebuild it.
I've tried but I haven't come up with a simple test. If I think of one I will let you know.
Good Luck
Paul
Car Battery Tester 12V Load Tester, TOPDON BT100 100-2000 CCA Automotive Alternator Tester Digital Auto Battery Analyzer Charging Cranking System Tester for Car Truck Motorcycle ATV SUV Boat Yacht
https://www.amazon.com/gp/product/B07Z6 ... UTF8&psc=1
