- Has thanked: 1502 times
- Been thanked: 3817 times
How anyone can remove a wheel bearing on a car with the knuckle on escapes me completely.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
a3inverter
- Year and Model: 2006 V70
- Been thanked: 9 times
That's how I did it recently too! Just needed the right set of wobble extensions from what I remember.
a3inverter
Replaced the plastic hinge on the fuel filler door and put new spark plugs (OE Volvo) in yesterday. Nice easy job. Plugs looked worn but no signs of bad stuff going on @179k miles. Based on the PO's records, they (OE Volvo) were last replaced @ 115k. The plastic loom for one of the plugs needed a few wraps of electrical tape and also took the opportunity to clean up the engine covers with soap and water. In the last couple months the CEL has lit due to the evap system (I'm forgetting the code) and I tweak of the gas cap has solved it.
Love how the fuel filler door opens with crispness now!
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
Muffler was still too loud at the flange joint between the cat and resonator, I decided to pull the whole system in one piece and got the car raised up.
On the off chance I decided to tighten the bolts on the flange joint , it did tighten up enough to stop the leak. So thats solved...again.
I found a slight phhhffft at the top of the flex joint but its not bad enough to bother with yet.
To fix that I'd still have the drop the system in one piece and build a wooden jig to make sure the system stays aligned when the flex section is welded in. Thats for another day.
I’ve become a huge fan of the band clamps that close with two 14 mm bolts and surround the joint with metal. If you have a little mismatch in pipe size you can make the smaller one with muffler Wrap tape. Roll under with the impact gun and zip zip, muffler connected
- Has thanked: 927 times
- Been thanked: 1000 times
These band clamps come in all diameters and are also available with different sizes on the ends. I made dual exhaust system for my Ford truck using these since I did not want to take to a welder.abscate wrote: ↑02 Sep 2022, 05:19 I’ve become a huge fan of the band clamps that close with two 14 mm bolts and surround the joint with metal. If you have a little mismatch in pipe size you can make the smaller one with muffler Wrap tape. Roll under with the impact gun and zip zip, muffler connected
