Hi Rick,
You are absolutely correct - problem was that i could not find the mount feature in the popup meny, so i extracted the .iso to a folder, thinking this would be the same!
Now i managed to get the mount feature installed by assigning the default app for .iso to Microsoft disk burner in the default app settings.
After mounting the .iso file, the scrips run fine, and i am back in process of install…
Thanks a lot for your swift response!
BR Espen
VIDA 2014D_Repack install on Windows 10, any version.
Espen Beck
- Year and Model: XC70, 2001
Espen Beck
V70XC Cross Country 2,5 AWD, 2001
XC90 R-Design 2,5D AWD, 2014
Espen Beck
Well - Hi again!
I have now managed to install, and everything seems to run smooth, except one thing; Dice controls does not show up under Communication Tool on the Vehicle Profile tab…
Only the headline “Communication Tool” is vissible
The popup window is missing
I have installed the Dice Tools from the 3PP/Products/DiCE folder
And DiCE Diagnostic app is testing the device OK
Firmware is up to date with firmware on the .iso
Did a custom install of the DiCE from the Script 02_VIDA - just to make sure
Restart several times
But it does not show up on the Vida page…
Any ideas?
BR Espen
Any ideas?
BR Espen
Espen Beck
- RickHaleParker
- Been thanked: 980 times
Red X in Communication Tool .... IE Hosting did not enable.Espen Beck wrote: 02 Sep 2022, 14:08
To fix:
Vida DVD:\Install\Utils\EnableIEHostingxxx.reg .
Make sure you run the right one for your operating system.
xxx =x64 is for 64bit operating systems,
xxx =x86 is for 32bit operating systems
Active
Past
Past
Espen Beck
Thanks but there is no red cross - bot popup is missing (attached image)
Tried to run the EnableIEHostingx64 anyway, but with no result - have restarted after also - still no popup
Any other suggestions?
I have two DiCE devices and one of them used to run fine with the Vida 2011 version, but now i am on a newer 2014 XC90, so i need the 2014 Vida
Appreciate all your help here!
BR Espen
BR Espen
Espen Beck
Espen Beck
Maybe a hint about what is the issue…
I get the localhost dialog shown in the picture if i try to select the car manually and then click ok…
Any ideas?
Any ideas?
Espen Beck
Espen Beck
Finally - I got it to work!
Reinstalled everything again, following your instructions and now it works, also with DiCE!
Thanks a lot for doing this write up, and for your continous support to help poeple like me getting this to work!
This is really amazing!
BR Espen
BR Espen
Espen Beck
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 674 times
- Been thanked: 164 times
Hy,
Better late than never...I've followed the first step but apparently, the link is not able anymore...
Manov
Manov
- RickHaleParker
The link is still good. The torrent is still alive. Last check showed 21 seeders and 56 peers.manovlov wrote: 27 Sep 2022, 11:57 Better late than never...I've followed the first step but apparently, the link is not able anymore...
Active
Past
Past
- manovlov
@Rick,
Well, it was my soft that wasn't right. The files still exist. Thanks to have checked this for me Rick.
Manov
Manov
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
The issue I anticipated is searching. Also duplicate + reused images etc. But nothing a few python lines can't fix permanently.matthew1 wrote: 30 Aug 2022, 22:17 I poked around in there with the same idea in 2008 or 2009. I don't recall the issues I ran into, but I recall abandoning the project (not for copyright reasons, for technical ones).
- 11299 Views
Last post by Stasiuss
- 5106 Views
Last post by big305
- 6073 Views
Last post by RickHaleParker
- 3284 Views
Last post by rusty volvo
- 4614 Views
Last post by wizechatmgr
