open loop on coasting?
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Last night, I decided to take a look at live data on the way home from work. I had smelled exhaust when sitting idling, much like I had when my O2 sensor was bad. I think it was just exhaust from the many other cars leaving the parking lot, as the O2 seemed to be functioning fine. I did notice that when I closed the throttle for a few seconds, such as when making an exit from freeway speeds, the car would switch to open loop for a second or two. Is this normal, or indication of a problem? I thought maybe it's the equivalent of a carb systems dashpot?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
No one has noticed this or has any insight?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 987 times
- Been thanked: 1076 times
Holiday weekend. Many regulars are not posting. I have no insight for you.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I saw this, but the only thing I know about it is that the car should be in closed loop when coasting. Maybe it has something to do with the ECU noticing the leaning out because your suddenly not demanding fuel, and it's figuring out what to do. I just installed a AFR gauge, and when I take my foot off the throttle and coast, the gauge will sometimes spike briefly off the chart. This is normal, so maybe your seeing something similar. All I got...
1999 V70 GLT
1999 V70 GLT
- Been thanked: 4071 times
I seem to remember short term fuel trim drops to 0 on over run which is probably telling upu it’s going open loop temporarily. I would have thought doesn’t set the open loop flag, but that’s why I don’t think too much anymore…
454cid
Yes, I did see stft going to zero.abscate wrote: 05 Sep 2022, 05:47 I seem to remember short term fuel trim drops to 0 on over run which is probably telling upu it’s going open loop temporarily. I would have thought doesn’t set the open loop flag, but that’s why I don’t think too much anymore…
I'm about ready to fill up with gas again, so I'll check mileage again..... it's been hanging right around 24.x-25.x mpg with mostly highway driving anywhere from 55mph-80mph.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Good mpg for a turbo. Bit low for an NA.
454cid
Hmm, it's only rated for 26highway. What's normal for an NA? Any ideas on what I should look at? I've got the tires aired up to 36psi, per the alternate air pressure printed on the gas door. O2 sensor got replaced with a new Bosch when the original pooped out, as did the TPS. Ignition has been done.... well original coil. LTFT hangs right around 3%.
I should replace the fuel filter, as I haven't done that yet.
I also have noticed that my miles traveled may be a little off.... no not because of tire diameter, but It seems the 850obd2 app only reports mileage to the nearest 10 miles.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Our two NA p80s get 30 mpg highway, my p2 34mpg
In dead of winter , they might drop to 28 mpg highway
My Evita log….
Hot test run to Boston at 65-70 mph
Returned 29.9 mpg on 91 octane
My Evita log….
Compare the MPH when these MPGs are reported. I suspect 454 may have faster highway speeds with A/C than Abs on cooler New England highways.
Fresh Volvo coils have been reported to improve mileage.
Your mileage may vary.
- 1491 Views
Last post by misha
- 1121 Views
Last post by SuperHerman
- 934 Views
- 13 Replies
- 5486 Views
Last post by theobviousfaker
- 1040 Views
Last post by precopster
