You can use the radiator and ignore the cooling ports, make sure you have the right transmission connectionsbrunocerous wrote: 07 Sep 2022, 08:53 Blue Steel ('98 V70 base AT) recently had its coolant light come on after a two-hour drive with two of my kids in the car, but I found a Napa and topped it off.
The right side of the radiator appears to have a leak about one-quarter of the way down. I see replacements with oil cooler ports, but is that only for turbo models? Mine does not seem to have these.
- Has thanked: 1613 times
- Been thanked: 4078 times
- Has thanked: 317 times
- Been thanked: 531 times
Oil coolers were only installed on turbos, however the radiator is 100% compatible with the NA cars. Just leave them disconnected.
The -'98 and the '99+ radiators are different though, so keep that in mind.
Edit- what abscate said! The trans cooler ports also changes in '99.
- Has thanked: 2215 times
- Been thanked: 1853 times
Thanks guys for catching that last important piece. I had forgotten to add the 98-99 change on the trans cooler side. Were they all changed or was the change for the 00 year on the cars with the 5 speed auto trans, or did they all change in 99?
I think it was a -98, 99/00, and then P2 solution
Pretty sure the transmission hoses for the 99 and 00 are the same part so same fittings
The trans cooler lines were all changed for '99-'00. 4 speed and 5 speed use the same lines.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Would recommend anyone who has the old style spray nozzles (2 hoses) to pick up some washer nozzles from any of these cars. My 98 had the old style and the upgrade is amazing for vision. Much more efficient spray of water.
Changed the front wiper transmission with one from a 2000 V70. seems to be a lot faster on the downwipe. Did the passenger wiper arm upgrade for the drivers side and a good amount more is covered by the blade at the expense of a 1 inch arc at the bottom of the windscreen on the drivers side. Overall worth it.
2008 S60 2.5T Auto (Sold)
Those fan-type nozzles are a must!
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I swapped to the fan type nozzle, but the Pro Parts version..... I would not recommend. I seem to go though washer fluid very fast. The spray is not high enough on the windshield. One of these days, I'll try something else.... maybe get some from a salvage yard, if I ever go and find a suitable car to pull from.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
You can save $18 with the PPS, or spend $24 for the ones that work.
That song has played so much it’s worn out the bits in the .wav
