1980 244 hard starting
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Sharpy
Year and Model:
Post by Sharpy »
Hard to start but will start with short turn on the key with no throttle then runs on 3 pots till warm. Smells very rich during warmup and a little rich when warm. Checked cold start valve, tried different injectors, plugs/leads, fresh fuel, injector cleaner and stuff. Any ideas?
wojeepster
Year and Model:
Post by wojeepster »
check temp sender (the one for the fuel injecton, not the one for the gage) If it is off it will make car too rich or too lean. clean idle air motor on top of valve cover. Use ngk plugs, I have had problems with bosch platimum, bosch std are ok. Platinum tip falls off.
Sharpy
Year and Model:
Post by Sharpy »
With no throttle it starts for about 3 secs then dies. But extreme fuel smell. anyone?
