So when I put my key in the driver door,
Opened the car up, alarm started going off.
Put key into ignition, and car wouldn't start.
Alarm still going off.
Tried locking and relocking, and also tried using the lock on the rear gate of the wagon.
No dice.
Any thoughts on where to start?
I'm about to disconnect the battery for a half hour, and then try again.
Car was working absolutely fine a few hours ago.
Thanks in advance for any advice , have to use the car in the late am tomorrow.
Al
98 V70 here is a new one ..alarm going off
- Has thanked: 2200 times
Do you have a fob? You need that to cancel the alarm when it goes off. You might be able to reset with a battery disconnect.
Also try locking and un-locking more than once.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
May be an issue with the the door
key cylinder's arm/disarm switch.
When you unlock at the door,
if you turn the key to open twice,
do the other doors unlock?
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
I don't have the fob.
I will try those other things and report back.
Al
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
Only the driver door lock will reset the alarm. If you lose continuity in the wiring in the door, the key will unlock the mechanical lock but not turn off the alarm.
surfbug1
Went out the next day and it's working fine.
Gremlin must have left! Lol
Ping me!
Ping me!
What did you use to scare off the Gremlins? I need some of that!
surfbug1
I just ignored them, and let them sleep overnight, and then they went away LOL.
Check out my latest debacle and problem on my latest post looks like my sunroof decided to do the F-16 ejection process!
Ping me!
Ping me!
surfbug1
Ok so alarm is going off again. Disconnected the battery. Hopefully it will reset.
Not good I'm stuck and the hurricane Ian is coming to Florida.....
Any thoughts?
Any thoughts?
Ping me!
Ping me!
- 16 Replies
- 4413 Views
Last post by 850 LPT
- 1720 Views
Last post by theWIFES_S70
- 9 Replies
- 2116 Views
- 538 Views
Last post by Clemens
- 9 Replies
- 4551 Views
Last post by kallekula
