Hi Neil,scot850 wrote: 16 Sep 2022, 16:06 I watched Robert's as usual helpful video below:
https://www.bing.com/videos/search?q=fi ... &FORM=VIRE
This got me thinking about making up a simple test system to:
1) Power the radio up
2) Allow the radio to stay on long enough to remove the dreaded 'OFF' if CODE set wrongly (I have one unit that does not accept it's code but I think it had a stuck button)
3) To check the functionality of the unit like CD-input and eject functions (especially 3-CD head units), cassette input eject as well as being able check all the bulbs are working.
Maybe down the line I might add a simple speaker function that would allow checking sound output as well as testing the amplifiers.
I have pig-tails from the 2 larger radio connectors.
I have difficulty following Robert's directions as to which wires to connect for power to get the units functional.
I plan to power this from a trickle charger with 2/4A output capability to save buying a 12V power supply. I also have a couple of 2/6A battery charger is more power is needed.
I want to make sure the system is safe for me to use and also safe for any head units attached to it.
This is a winter project but any design guidance is appreciated!!
Many thanks,
I would be careful about what i used to power it as some battery chargers can put out a much higher voltage when not loaded properly. Some may even put out sqrt(2) times the nominal voltage of 12v, which is 17 volts and could be as high as sqrt(2)*14v which is 19.8 volts, peak.
Regular power supplies are made to hold a constant DC voltage i would think that would be safer.
You can get some on Amazon for a reasonable price, even find a unit that puts out up to 30v at 5 amps for around $60 and for lower amps around $25 USD maybe. That makes sure the radio does not blow out.
I would hate to hear that one of the test radios blew out on you.
