oil filter wrenches and filter sockets
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I changed my oil today. I had a Mahl OC204 on there which has the flats enabling the use of a cap style filter socket. When I installed it, I was using my uncle's garage, and used his socket. I don't have one the correct size here at home. I removed it with a strap wrench (made of seat belt material), as there isn't clearance for my metal band type wrench that I typically use on my truck.
When I re-installed a filter, I used one of the smaller diameter ChampXL synthetic filters that I bought (PH2835XL). I have a filter socket that will work on that filter.
I also have a Mann which I know many here prefer, and those don't have the flats for a filter socket. I can get a filter pretty tight by hand, although I usually turn them just a bit more with a wrench. I typically can't remove them by hand. How do you install/remove them?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
After a few failures to remove filters without total destruction, I use a half turn from contact method after oiling the gasket. Most often this is about fully tight by hand. This method has never had a leak on any vehicle. I typically have to use the steel band clamp to loosen.
454cid
Post by 454cid »
volvolugnut wrote: 24 Sep 2022, 18:39 I typically have to use the steel band clamp to loosen.
Hmm, how are you getting clearance for that? I tried putting the band at an angle, but I didn't want to permanently bend the band. It seemed to me that the subframe/cradle was in the way, of the handle, but maybe I didn't spend enough time with it before getting my strap wrench.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
454cid
Post by 454cid »
I had forgotten about the 3-legged type. I've never used that design. Do they grab the filter well, or do they tend to slip?
I've seen "pliers" made for filters but have never used them. I can see large Channel Locks working, and unlike the band type filter wrench would probably work at a downward angle. Very large Channel Locks are what I used when installing a new serpentine belt.... I should probably buy a pair even if I don't use them for filters.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
MoVolvos
Post by MoVolvos »
454cid wrote: 24 Sep 2022, 20:03
The large pliers only need to budge the filter a little and the rest is easy. The 3-legged is hard to start up but wrapping a rubber band around it (just thought of that) will help the legs stay in contact with the filter. It will crush the filter thereby making it easier to remove if indeed the filter is stuck. The cap type is hit and miss in terms of quality. Some are not formed well or sized too large for the stated size. The pliers is my first choice when changing oil.
Forgot where I saw this yesterday but the filter is tightened 1 full turn after making contact then backed off just a little. Oh, a zip lock is part of the tools as it wraps around the filter, when possible to catch the oil. 03 Honda Odyssey.
454cid
Post by 454cid »
MoVolvos wrote: 24 Sep 2022, 21:07 The large pliers only need to budge the filter a little and the rest is easy. The 3-legged is hard to start up but wrapping a rubber band around it (just thought of that) will help the legs stay in contact with the filter. It will crush the filter thereby making it easier to remove if indeed the filter is stuck. The cap type is hit and miss in terms of quality. Some are not formed well or sized too large for the stated size. The pliers is my first choice when changing oil.
It sounds like I need to find the right size cap or maybe use the strap for the smooth Mann filter. I'm mostly concerned with finding a good solution for installation....for tightening just a bit more than hand tight. Today, I used a smaller filter, but later when I go back to the standard diameter, I'm not sure that I'll be able to grab tightly a hold of it given it's proximity to the pan sides.
I did have a plastic cap snap in half several years ago.
I've heard of using a bag, also seen a cup demonstrated. I could try it, although I'm not crazy about having an oily bag.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Been thanked: 4065 times
Added to my toolbox of knowledge. Brilliant.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Strap type to remove - hand tighten apx 3/4+ turns from point of contact. I can honestly say that after doing this for more than half a century
( damn that sounds long ) on many many cars & trucks, I have never had a leak. Except for that one time when I poured in 4 quarts of oil, but forgot to install the new filter. " Why are my feet wet and slippery ? "
1999 V70 GLT
454cid wrote: 24 Sep 2022, 19:16
I don't have an 850, so these are general directions for oil filter install and removal. I have one cheap oil filter band wrench that has a swivel that allows the handle to pivot and avoid some objects.
