1998 v70r unknown sensor
Janpy
Year and Model: 1998 v70r classic
Post by Janpy »
Hi
In the right front behind the frontlight i found
A black sensor, with one wire cut.
Does any one know where its for?
In the pc
In the picture is the sensor and the connector
With a blue white wire and a dark wire, cannot see the color.
Thank you
Jan
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
There is usually temperature sensors for your dashboard and ecu in bumper. Warning i am writing top of my head again.
Has thanked: 2210 times
Been thanked: 1852 times
'i don't see any picture or attachment to be sure what you are talking about.
However, trying to recall what is there. There could be a black wire if I recall for the security system if someone tries to open the hood with the alarm set, there is also the altitude sensor mounted by the hood latch. Can't think of anything else.
The 2nd item I would expect to throw a code if not connected.
Janpy
Post by Janpy »
Sensor and connector
Here is the sensor
It could be a water level sensor for the windshield washer fluid bottle warning light?
SwedishMadeFunBrick
Year and Model: Saffron 1998 V70R
Has thanked: 11 times
Been thanked: 4 times
Post by SwedishMadeFunBrick »
Where the heck is that sensor in the first picture? I don't see it 🫀
Has thanked: 1611 times
Been thanked: 4075 times
scot850 wrote: 01 Oct 2022, 14:45 It could be a water level sensor for the windshield washer fluid bottle warning light?
I think you nailed it. I was clueless and stumped
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 115 times
Post by Goupil »
Yep that's the washer fluid lever sensor, I've had to replaced mine before.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
I got tired of breaking my coolant level sensor I finally wrote a note to myself on top to remind me
Janpy
Post by Janpy »
Thanks for the reply's
In the first picture there is only the connector.
I will check the coolant or washer fluid sensor.
The sensor now was put in some hole in the cars metal frame behind the headlights
Jan
