P1113 Ambient Air Temp Topic is solved
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Can someone please point me to this part. Seems to be discontinued and the Volvo online diagram is confusing so don't have any idea where it is?
"P1113 Ambient Air Temp DTC Severity 2 of 3: Repair Immediately if driveability issues are present."
https://www.autocodes.com/p1113_volvo.html
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
On which car from your fleet?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2199 times
Been thanked: 1851 times
There are usually 2 on V/S/C 70 P80's. The temperature readout in your car if it has it, has one sensor the other is the ambient temperature sensor for the engine.
The engine temperature one should be just to the left of the center (standing in front of the car) air intake below the hood grille, and you should find it clipped into the air deflector tray under the car. It means the tip faces into the lower grille aperture near the front of the tray.
P80 air guide
P80 air guide
If you look at the picture above, there is a round hole in the air guide perpendicular to the sticky label on the LHS of the picture.
The dash ambient temp gauge looks identical and should clip into the RH lower grille on the bumper from the rear between the slats.
The drawing for location use is hopeless but the part is #1 on the attached link. Does not say it is NLA, but not asked about it:
https://www.volvovancouverparts.ca/a/Vo ... 31755.html
MoVolvos
Post by MoVolvos »
misha wrote: 04 Oct 2022, 13:41 On which car from your fleet?
Oh, that would help. The 2000 S70 SE Base. Thanks.
MoVolvos
Post by MoVolvos »
scot850 wrote: 04 Oct 2022, 16:04
Thanks, I saw that one. Hopefully the person who put the diagram together doesn't work at Volvo any more.
MoVolvos
Post by MoVolvos »
scot850 wrote: 04 Oct 2022, 15:38 There are usually 2 on V/S/C 70 P80's. The temperature readout in your car if it has it, has one sensor the other is the ambient temperature sensor for the engine.
I'll give that a look thanks!
MoVolvos
Post by MoVolvos »
Found 2 sensors. First one is left of the vent / grill where the driver's side fog light goes. I don't have fogs however. Used the teeth of the needle nose plier's to gently pull and scrape the pins of any oxidation and then applied dielectric grease. Also bent the pins ever so slightly for tighter contact and pulled and pushed into socket a few times to clean the socket plug.
The second sensor is under frame at the end of the splash guard on the passenger. Do not have to remove the splash guard for access. Mine was not installed properly so I removed it. Found several wasp / mud nest.
MoVolvos
Post by MoVolvos »
Didn't work though?
That is not where the 2nd sensor goes. It plugs into the undertray as I tried to explain in one of my previous posts. That ensures it is in the ambient air intake which the engine uses to regulate air/fuel.
