Good afternoon.
My xc70 has developed an oil leak just at the turbo drain connection at the base of the turbo housing. Other than taking the awd chunk out are there any other methods to stopping the leaking. At least that is where I believe the leak is located.
Thank
P
2003 xc70
Porkchop32
- Year and Model: 2003 xc70
Porkchop32
Good afternoon.
Thank
P
Thank
P
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
No, you shouldn't have to fool with angle gear, you'll need this gasket I think.. if it's where I think it is oil return tube into oil pan. rockauto.. 2.37 $... MDK
- 00764900__ra_m.jpg (4.7 KiB) Viewed 270 times
It’s a lot easier on a lift with anAWD.
I think the stock bolts are H5 hex internal head on m6 threads. A bit odd ball. A ball H5 head makes this easier
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
get the gasket and bottom green O ring for the pipe, extended drive allen hex head to get up there.
I paid $7 at the dealership for the parts. Its awkward getting the bolts started.
Remove the drain pipe, clean the top, let dry and stick the gasket in place with gasket shellac.
Try FCP for the extended hex socket driver.
- 1107 Views
Last post by precopster
- 10 Replies
- 2963 Views
Last post by 321lor
- 1107 Views
Last post by draser
- 2895 Views
Last post by MoneyPitC70
- 2958 Views
Last post by SuperHerman
