I think everything is clear in the picture
Vida CEM swapping
matija0610
- Year and Model: 2003 S60 D5
- Has thanked: 21 times
- Been thanked: 13 times
8-bit SUM whole CONF block
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
ele288 wrote: 07 Oct 2022, 16:09 You can use cem cracker or read directly from cpu and find the pin. If you look at page 9 there is details where the config is, but if you change any byte you have to recalculate checksum but can't figure this out yet
Page 9 From what the microcontroller datasheet or something else ?
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
Registered on their site. No datasheet for the M32C, and can't find a dev environment to dl there eithervtl wrote: 27 Sep 2022, 16:35Solve it!konielian wrote: 27 Sep 2022, 13:32 I am also interested on making an app which can write back by DiCE the modified flash into the car, thanks to T5Luke, on 28f400 cem that is possible but in the M32C CEM is still not solved.Register at Renesas web site, download M32C datasheet and development environment. Renesas E8/E8a is slightly over $100 on Ebay. You will need a donor CEM, too. Once you have a flash-writing SBL ready, you are basically done. The CAN proto is very simple and wouldn't take long to implement.
oscilloscope
Are you refering to the older brick style cem with the MC68376 ? Or is there another one which uses the 400 flash memory externally?5ft24 wrote: 08 Oct 2022, 16:18 Finally found the HEW/compiler/debugger etc, but still no data sheet for the M32C
oscilloscope
Is this what you're after?
REN_rej03b0047_32c84ds_DST_20050708.pdf- (903.63 KiB) Downloaded 177 times
- 9221 Views
Last post by RickHaleParker
- 9137 Views
- 27 Replies
- 28331 Views
Last post by cn90
- 10 Replies
- 10596 Views
Last post by jonesg
- 5733 Views
