Front End Work
Has thanked: 312 times
Been thanked: 818 times
Most of the stuff on your list is very typical to fail by this mileage, but not the brake master cylinder. Make sure you get a second opinion on that one, it is very unusual for that to fail.
S1L3NTSH0UT
Year and Model: 2002 V70 XC
Has thanked: 2 times
Post by S1L3NTSH0UT »
erikv11 wrote: 25 Sep 2022, 21:01 Most of the stuff on your list is very typical to fail by this mileage, but not the brake master cylinder. Make sure you get a second opinion on that one, it is very unusual for that to fail.
That's interesting. I had it towed to a shop about a mile from me (it's a reputable place with solid reviews) because it was sitting for quite a while and wouldn't start. Aside from a battery replacement since the old was actually bad, they did a brake fluid flush and replaced the hoses. That's when they told me about the master cylinder. I can brake but the pedal pretty much goes to the floor.
Another thing I've been noticing over the last 2 weeks or so is that the engine seems to be burning something. I read about the PCV and tried doing the glove test, and it passed. I replaced the oil cap gasket and got an oil change since it was due about now anyway. I smell something burning when it's been running for a while, and I've been noticing what looks like a light layer of black soot accumulating on the car, as well as these weird little clear speckles on the back window. I do notice a slight leak under the car but I can't tell what it is because it's clear and none of the fluid reservoirs in the engine compartment seem to be getting lower (or the oil for that matter).
wch2032
Year and Model: 06 XC70
Has thanked: 11 times
Post by wch2032 »
Is the "pedal to the floor" only at engine start-up or is it throughout an entire drive? If the former, could be the brake vacuum switch. My brakes were very soft at engine start that it made pulling out of park quite scary, got better after running for 15 mins or so.
https://www.fcpeuro.com/products/volvo- ... o-31265825
jonesg wrote: 22 Sep 2022, 19:10 I would opt for quick struts. Its a 20 yr old car, no way I would pay dealership prices .
https://www.completestruts.com/product/ ... ab-content
Take the quick struts to a different garage and pay for installation.
Have you used these struts before?
06 XC70 - 251K
S1L3NTSH0UT
wch2032 wrote: 29 Sep 2022, 11:47 Is the "pedal to the floor" only at engine start-up or is it throughout an entire drive? If the former, could be the brake vacuum switch. My brakes were very soft at engine start that it made pulling out of park quite scary, got better after running for 15 mins or so.
It is pedal-to-the-floor for the entire time the car is running/driving.
Okay definitely sounds like there is a brake problem, could be the master cylinder yes. Could the clear li=quid be brake fluid - did you check the level of that reservoir too? Maybe there is a leak at the MC.
S1L3NTSH0UT
erikv11 wrote: 03 Oct 2022, 11:13 Okay definitely sounds like there is a brake problem, could be the master cylinder yes. Could the clear li=quid be brake fluid - did you check the level of that reservoir too? Maybe there is a leak at the MC.
It could be possible, I haven't checked the reservoir in a few days. Last time I was in there I did notice a seeping from the power steering hose that is under the PS reservoir (the larger hose). I went ahead and tightened the hose clamps on both hoses. The container didn't really look like it was that low though. Maybe it's a combination of both things.
KurtL
Year and Model: V70R 2005
Been thanked: 5 times
Post by KurtL »
I had a 2001 V70 2.4T. I got quoted $2600 to do the struts and control arms. I bought the parts and tools for $950 and did them myself. It wasn't too hard. I probably spent 15 hours on it since I had never done it before. Saved me $100/hour and kept the car from getting junked.
After I bought my 2005 V70R I replaced the same parts.
Has thanked: 1611 times
Been thanked: 4075 times
KurtL wrote: 08 Oct 2022, 20:49 I had a 2001 V70 2.4T. I got quoted $2600 to do the struts and control arms. I bought the parts and tools for $950 and did them myself. It wasn't too hard. I probably spent 15 hours on it since I had never done it before. Saved me $100/hour and kept the car from getting junked.
…and you probably got 100k mile parts, not 25k mile parts…
Has thanked: 2211 times
Been thanked: 1852 times
If you are getting a white colored smoke from the tailpipe it could be brake fluid. Watch the level. A soft pedal can also be badly bled brakes or failure of the brake booster pump.
