If I remember correctly, earlier turbos (MY01/02?) don't have it.
Brake Booster in-car seal replacement, question for Oragex
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
FCPEuro sells vacuum pumps that fit them.
- gnalan
I didn't know that. I'm not even sure where the vacuum pump is located on the turbo cars. Mine is NA and puts out plenty of power for me to get around with.
Sorry if I mislead anyone.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Imagine torque you have at 4000 RPMs. Multiply it by ~1.33 and stretch evenly between 1500 and 4500 RPMs. That's 2.5T.
Imagine all the parts that break semi-often in your car, and maintenance items that you need to take care of routinely. Multiply their quantity by 3, divide average life span by 2. That's 2.5T AWD
Still miss my N/A 02 V70.
- Has thanked: 1611 times
- Been thanked: 4075 times
Multiply by 6 if driven by a male under 25 pre-brain operationvtl wrote: 23 Mar 2022, 14:44Imagine torque you have at 4000 RPMs. Multiply it by ~1.33 and stretch evenly between 1500 and 4500 RPMs. That's 2.5T.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Preparing for the brake booster service. Am I to replace vacuum line 10, 18, 20 & 22? Would the hose from local O'Reilly suffice - what is ID?gnalan wrote: 21 Mar 2022, 15:24 If you're going to replace the brake booster you should replace the vacuum lines while it's out, too. You'll have more hand room to replace them, and one less thing to worry about in the future.
- gnalan
I haven't replaced mine so I'm not sure. I think the ID is different that what you can get at a local parts store. I'd go with Volvo original parts to keep from having any sort of vacuum leak from the wrong size hose though.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I also need to do mine. In as little as 10 minutes after stopping the car, the brake pedal is as firm as a rock. My other older volvo doesn't do this, there's vacuum there even after a few days or a week.
