2001 V70 2.4T Blower fan stopped working Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I have run a TYC fan in the wife’s XC for nearly 4 years now. A possible good cheap alternative to Behr/Volvo.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
Anyone know how to parse the dates on the part numbers in the photos above? The fan seems to say 08 11 01 which would be November 8 11 2001 in European format or August 11 2001 in American. The resistor has an 011012, which seems like a date of either October 1 2012 or January 1 2012. Or October 12 2001 if it’s in YMD format. I have a vague feeling that I’ve replaced the resistor at some point, so January 1 2012 would make sense in that case.
Cars I've owned:
- br0dy519
For a price. Granted, the TYC was certainly an improvement over the prior blower which sounded like a cricket was bring tortured,
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- prwood
FCP has the Mahle-Behr blower motor for $183.49. RockAuto has the TYC for $97.79, also has Four Seasons brand for $90.79, and VDO/Continental for $108.79.
FCP Mahle-Behr: https://www.fcpeuro.com/products/volvo- ... -9171479-1
RockAuto TYC: https://www.rockauto.com/en/moreinfo.ph ... 19&pt=6916
RockAuto Four Seasons: https://www.rockauto.com/en/moreinfo.ph ... 19&pt=6916
RockAuto VDO/Continental: https://www.rockauto.com/en/moreinfo.ph ... 19&pt=6916
Trying to decide if the sound on the TYC is bad enough to spend an extra $100-ish on the Mahle-Behr, or if one of the other brands I mentioned would be good as well. I have hearing loss in the higher ranges at lower decibels, so if the TYC sound is high-range/low-decibel I might be able to live with it!
Cars I've owned:
- br0dy519
T Y C , T Y C!!!
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Can I butt in with a dumb question?
Why do they recommend always replacing the resistor as well? How does it fail?
Resistance is futile , with Borg Warner parts….BlackBart wrote: 11 Oct 2022, 08:10 Can I butt in with a dumb question?
…(ouch)
- BlackBart
Ouch. I guess if it quits just replace both. 130,000 mi, I'm about due. He makes some random squeaks / shrieking until the system warms up in the winter.
- prwood
Hi folks, just to let you know the resolution - I ended up replacing just the blower motor with the TYC model and it is working great! Kept the old resistor (which, as I mentioned above, looks like it may have been replaced more recently). I do notice a slight whine when the fan is blowing at maximum, but it's not that bad. Thanks again for all the advice!
Cars I've owned:
- 675 Views
Last post by oragex
- 2224 Views
Last post by Sixthandredline
- 1570 Views
- 871 Views
- 11 Replies
- 1624 Views
Last post by Acetheprince
