Looking at a couple of P2s
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I'm going to look at a 2001 V70 wagon. It has a transmission service light on. I'm also at least partially aware of issues with 2001 transmissions. Does this message necessarily mean an error in function or is it also used for an ATF/filter change reminder? I've never heard of such reminders for the transmission, but I'm new to European cars. The auction listing says it drove fine, but I won't be able to drive it myself, just pull forward and reverse back into it's parking spot.
Is there anything I can easily check when I look at it? Should I avoid this car based on the service light alone?
The car only has about 82K miles on it, but I'd rather not have transmission issues with a car I need to start driving right away.... I want to get my rust free 850 off the road before winter.
There's also a 2006 XC70 Cross Country. It has about 102K miles, It's got a missing driver's side CV shaft and "vehicle shutters at time while driving because of it". I would think the CV shaft wouldn't be a big deal to replace, but I have my doubts about that being the cause of a shudder. The AWD sure would be nice this winter.
I'll have a cheap scanner with me, but I doubt it'll tell me about Volvo specific codes.
Any advice would be appreciated.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Well, for that transmission, if the car (wagon) goes into "limp" mode it might need what they call a park neutral safety switch which is mounted on top of the transmission under the air cleaner A good flushing with this stuff (16 quarts ) could never hurt ..
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
When my 2001 V70 transmission started acting up, it was not immediate failure. Try to check the fluid level, smell and color. The code might clear and it will drive OK for a while. A fluid flush may help, but new fluid in a nasty trans may loosen all the gunk and cause filter block with sudden death.
Replacing CV shaft is not a big deal, but several hundred $. I would try as used axle to check out the rest of the car before spending money on new axle.
Try to buy cheap with these unknowns and unknowables.
Has thanked: 312 times
Been thanked: 818 times
My experience with the P2 used car market is that most of them do not have functioning AWD. Haldex pump is usually bad, less commonly it is a bigger issue like with angle gear.
You can check with VADIS or by getting all four wheels up in the air.
454cid
Post by 454cid »
2001 v70 is a no go.... it's got evidence of mouse activity, and it's sluggish pulling out of its parking spot.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
erikv11 wrote: 18 Oct 2022, 11:01 My experience with the P2 used car market is that most of them do not have functioning AWD. Haldex pump is usually bad, less commonly it is a bigger issue like with angle gear.
Oh, I thought the P2 system was better than the P80 awd system. I did talk to the man that evaluates the cars for the auction house, and his impression was that the shudder was caused by the CV shaft missing, since it can't transfer power the way it was designed. Could that be a pump issue? What does the pump actually do?
They've also got an XC90, but I have not researched that at all, yet.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
P2 AWD is definitely better than P80, and 06-07 is the best of the P2.
The pump is at the rear to recirculate/filter the oil in the Haldex unit and when it goes out the AWD shuts down. Not likely related to a shudder especially one up front. The good news is it is not too hard to fix (but in the rust belt watch out ...) and then the AWD hums along again. There are some other Haldex issues that come up, too. All require the same effort to fix: Drop the prop shaft (not trivial), disassemble at the Haldex, reassemble, refill the Haldex oil, re-install drive shaft.
We may have a terminology issue here, the CV shaft can't be missing/absent on a P2, is it the "prop shaft" i.e. the rear drive shaft that is missing? Or what do you mean by "missing?"
454cid
Post by 454cid »
erikv11 wrote: 18 Oct 2022, 13:59 We may have a terminology issue here, the CV shaft can't be missing/absent on a P2, is it the "prop shaft" i.e. the rear drive shaft that is missing? Or what do you mean by "missing?"
This is an auction car.... ANYTHING can be missing :D
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Wow! I've never seen that! It's got low miles right? Don't know why they'd remove that CV shaft and continue to drive it, definitely where the shudder is coming from but the bigger question is: why did the remove it and not put another shaft in?
2003 XC 70 (sold)
Has thanked: 1614 times
Been thanked: 4078 times
I don’t think you can remove a single axle shaft and drive the car. Wont the front diff just spin?
