One other path to a cat. You can buy a car at auction , part it out and recover most of your costs, and essentially get the cat for cost of part out labor
One of the sites, Philadelphia, actually has an underbelly shot of the cars so you can see the condition of the cat pre-purchase
S70 Catalytic Converter Availability?
- Has thanked: 1611 times
- Been thanked: 4072 times
AtomicForces
- Year and Model: S70, 2000
Last week I took my S70 to an exhaust specialty shop in PA and they welded in a universal catalytic. The check engine light has stayed off since. My state inspection is next week so hopefully it will pass.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi Steve,abscate wrote: 15 Sep 2022, 12:08 You dont have to be CARB compliant in NY as long as the OBD doesnt code for cat throughput you will pass inspections. You are also only 3 years from no emissions inspection at all!
I have a some P80 cats but I dont think they are turbos, your downpipe and diameter are different
Have you asked Brumsted at IFC Service if he can find one?
Go Big Red!! Are you attached to CHESS (guess from username)
What did you mean by "only 3 years from no emissions inspection at all!"?
In NY at 25 model years , OBD compliance is no longer required. Next year , in 2023, my 4 1999s will pass the last test for codes , in 2024 it will just be safety inspections
- Has thanked: 2207 times
Yes, then you can start the end of the world with exhaust emissions unchecked!!
Up here we have been doing that for years! No emissions checks in the 20+ years I have lived here. Not sure any repair shops even have equipment to test emissions at the tailpipe. I think they only rely on check engine lights here.
- bcfischer
- Year and Model: 1999 V70xc
- Has thanked: 14 times
For those of you (Abscate, Atomic Forces, and Kallekula to date) with third party replacement Cats, do you recall which model you got and where in the mix you are putting the downstream O2 sensor (if at all). The Cat on my '99 V70 XC rusted from the inside out and, as an emergency resort, I had a muffler shop straight pipe it as a Cat delete with the downstream 02 sensor just bung'ed into the new length of pipe.
Take care and stay safe all,
Brian
Brian
Brian Fischer
Duluth, Minnesota, USA
late year 1999 V70XC (Chassis 587997)
The only aftermarket cat I have is a Bosal on the Kat, but I didn’t source it. It came with the car as bought. It passes all the OBD tests without codes.
I bought one used Cat from a member here as it was cheap and I thought it would be good to have a spare.
Listed at $125, I sent a pm to buy which he missed, and then he lowered the price. I sent him a pm thst I would honor his original first price. He shipped it happy, and I picked it up at my office. On the way home , my original cat dropped off, and I pulled into my indie with the part in the trunk.
…and some people still don’t believe in karma ….
- bcfischer
Serendipity.abscate wrote: 19 Oct 2022, 05:07 I bought one used Cat from a member here as it was cheap and I thought it would be good to have a spare.
The Norse Volvo gods, who do not always smile, smiled on you that day!
Brian Fischer
True Karma would it was still on your shelf! But the gods were smiling on you that day for sure!
- bcfischer
With a CAT delete and the downstream O2 sensor plugged into the bare exhaust pipe, would the engine throw a particular code or would the fuel-air mixture be thrown off?
I live in Minnesota and, although we like our clean air and water, I am not required to smog test my car. I'm seeking the lofty goal of no CELs.
I'd like to replace the CAT, but it is not project priority number one on this car at this time.
1999 V70 XC (Chassis 587997)
Brian
Brian
Brian Fischer
- 16 Replies
- 2581 Views
Last post by FireFox31
- 4961 Views
Last post by MadeInJapan
- 17 Replies
- 4248 Views
Last post by E Showell
- 1959 Views
Last post by Ozark Lee
- 340 Views
Last post by calvolvo
