Vida CEM swapping
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
Furthering on with the wiring changing to 30awg on the transmission lines.
It remains to be seen If it works. , I haven't checked the other cem but it's worth ago once again. Just encase
oscilloscope
oscilloscope wrote: 22 Oct 2022, 17:10 Furthering on with the wiring changing to 30awg on the transmission lines.
Something very odd happened lastnight during testing, I had it all connected up with the alternative wires , but tiredness prevailed, and I didn't switch on the power supply. But the cem cracker was working away as if it was on and reckoned it was working through the cem.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
oscilloscope wrote: 22 Oct 2022, 23:56 But the cem cracker was working away as if it was on and reckoned it was working through the cem.
Look at the schematic. The transceivers are connected to the USB 5V. It powering off the USB. You don't need an external power supply for just CAN Bus. K-Line would be a different story but the CEM-B is still uncrackable and we found a way around the K-line if anybody does ever come up with a crack that works on the CEM-B.
Active
Past
oscilloscope
RickHaleParker wrote: 23 Oct 2022, 06:07
That's fine , I wasn't sure what vtl ment if there was something else I was suppose to use. , I have indeed powered the transceiver modules i have with the teensy.
Which one is the cem-b The brick style one ?
oscilloscope
Excellent
The £20 quid cem was able to be cracked. , my next task to see If it works in IOT terminal
XCGuy
Year and Model: XC70 08
Post by XCGuy »
Good job :) really helpful tool.
oscilloscope
Do you mean via an open source obdii reader where the k-line source code is freely available?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
You can connect to CAN via REM, etc, where k-line keep alive is not necessary.
BTW, the cracker supports k-line, just needs a chip and a couple of resistors. Mine has it.
oscilloscope
vtl wrote: 25 Oct 2022, 16:16 You can connect to CAN via REM, etc, where k-line keep alive is not necessary.
Would that mean it can support the older brick style cem ? With the correct supporting ic and Resistors?
RickHaleParker
oscilloscope wrote: 23 Oct 2022, 06:34 Which one is the cem-b The brick style one ?
Yep ... 1998 - 2004 P2. I could not come with a official name for it so I named it CEM-Brick.
Active
Past
