1998-2000 S70 / V70 Air guide thread 1397236
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Re: 1998-2000 S70 / V70 Air guide thread 1397236
Post by foggydogg »
abscate wrote: 24 Oct 2022, 06:05 It looks like Evita’s air guide has finally given up
Not available from Volvo, but EU guys n get one from Skandix
Parts geek shows the APA or URO one out of stock
IPD has an aftermarket but it’s $90mplus $80 dimensional shipping. Ugh
Looks like scarce p80,PnP hunting
If desperation sets in
www.amazon.com/URO-Parts-9190835-Splash ... 13d670b6bc
Free ship, with luck the link followed through MVS
These folks claim to have 74 (!)
www.carid.com/uro-parts/engine-splash-s ... k0QAvD_BwE
And of course I have a couple stacked out back.
Has thanked: 1506 times
Been thanked: 3822 times
Ordered the URO and will giveA review.
Thanks foggy!
Shipped in two days from Amazon poorly packed with both tabs snapped off
Amazon sending replacement after URO customer service approved. They were responsive in two hours by email, well done URO
Has thanked: 1853 times
Been thanked: 1714 times
Well that is unfortunate. Do you have to return the original? If it had happened to me I would have reinforced the broken tabs and plastic welded it back together and kept it as a spare.
Successfully received the second URO replacement. This is a nice piece of kit and was well packaged. Hope to put it on Evita today
Did not have to return first, so will try and patch that up, as I have four cars this fits!
foggydogg
Post by foggydogg »
abscate wrote: 03 Dec 2022, 04:01 Successfully received the second URO replacement. This is a nice piece of kit and was well packaged. Hope to put it on Evita today
Comes with the grille insert too !
As mentioned before, I've had good luck with ABS cement, and if you use scrap for a couple reinforcement straps on the outside surfaces, that should give enough strength to hold it on the car unless you're planning any off-road excursions.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
There a ton of ideas for using super glue to mend plastic with baking soda, paper, string, cotton, etc here:
https://www.youtube.com/@Inventor101
I use Plastic 2 part glue from JB Weld. I also have a small propane plastic welder. Bit like and oversize soldering iron but it has a hole in the tip you can pass sticks of different plastic types through like a welding rod. You can as suggested add in a piece of thin metal for reinforcing the crack and either glue it or use small self threading screws. That is hoe I repair the lower dashboards as well.
Uro air guide on Amazon down to $57 with free shipping!
454cid
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
I bought the 850 version from Autoplicity, through Amazon.... and am immediately returning it. I don't see damage to the box, but one tab is cracked and the other is completely ripped off and in the bottom of the box.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
