2007 XC70 timing belt change. Do-able at home?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
AylmerQc wrote: 03 Nov 2022, 07:11 I just found out from the previous owner that the timing belt was last changed in 2013 at 110,000.
It now has 200,000 miles.
Is this a job I could do at home on a weekend, or a week, taking my time?
I've done lots of mechanical work on my own cars over the years but no timing belts.
I have a pretty good idea of what's involved generally but wondering how complex it is on this particular car...
it becomes only slightly more complicated if the cams are CVVT equipped, especially the spring loaded ones. Precautions are taken when reinstalling the new belt to load the sprocket to its sprung position ( to the timing marks) first before the teeth in the belt engage the gear.
water pump bolts are only 12 ft lb torque, go easy on them. Snug em down then add maybe 1/8th inch more.
AylmerQc
Year and Model: 2007 XC70
Has thanked: 62 times
Post by AylmerQc »
Thanks again Jonesg.
I had to look up CVVT and from what I can see my 2007 XC70 has this.
Looks like any Volvo post-1999 has it..?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
2.5T (B5254T2) engine has VVT on both camshafts.
Dave0304XC
Year and Model: 2003 XC70
Been thanked: 3 times
Post by Dave0304XC »
Ay- I did the belt, water pump ect on my 03 XC70 a couple of summers ago. It went fine for me. I did build my own cam lock thing, 4 bolts that indexed to gear notches. I marked the old belt with 2 dots of paint and transferred those dots to the new belt. It went well and the car started with no CEL. Way easier than the T Belt I did on my wife's 03 new Beetle turbo!! Dave
jonesg
Post by jonesg »
clever enough to make a video with measurements.
deano1
Year and Model: 2001 s60 1999 awd
Has thanked: 13 times
Been thanked: 17 times
Post by deano1 »
Dave
That cam pulley lock system you made is genius!
I've seen other push in type and would create a false sense of security
Especially when dealing with the dual VVT normal procedure end up locking opposite end of camshaft which creates extra work but allows access to cam seals.
If cam seals are not leaking your rig could be used and timing problems would be thing of the past.
Cheers
jonesg
Post by jonesg »
deano1 wrote: 13 Nov 2022, 06:41 Dave
Cheers
i was going to make my own until....
https://www.aliexpress.us/item/32568033 ... _shipto=US
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
jonesg wrote: 13 Nov 2022, 08:49
Cheers
Perfect. Thanks for posting that. AliExpress is so great for stuff like this.
04s60 2.4
04xc70 2.5t
jonesg
Post by jonesg »
br0dy519 wrote: 13 Nov 2022, 10:00
Cheers
Amazon has it too.
and ebay.
SUNRG
Year and Model: '93 240 Wagon
Has thanked: 2 times
Post by SUNRG »
Blacklab467 wrote: 03 Nov 2022, 21:09 Just mark the old belt with a white marker and mark the index marks with white and transfer the marks to the new belt and away you go.
Great tip!
Previous: P1800, 760 Turbo Diesel, 760 Turbo Wagon, 940 NA Wagon, 850 Turbo Wagon, 242 (x2), 245 (x5)
Current: 2006 XC70, 2011 XC70 T6
