MVS Buddy Project
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
The intake manifold gasket is available by Volvo but with 2 weeks. Send directly from Sweden... Even though mechanic teaches me to be patient, i don't want to wait so long. Ordered on a french website, will get it Wednesday next week...
I've found the hose from the PCV at the junkyard. Will get it next friday. 29 $ from a 850 with 111 000 miles.
manovlov
Post by manovlov »
Today, it's injectors party. I've cleaned the outside. It's not what will make them getting better. But it's done.I will test them later.
The reference of mine is :
Injector reference.jpg (59.42 KiB) Viewed 377 times
Bosch gives me 15,9 ohms (Haynes), my ohmmeter gives me the following values, all the same :
Capture d’écran 2022-11-05 à 20.15.53.jpg (29.02 KiB) Viewed 377 times
Before
After
Get the inside filter out
Seals episode
Injectors seals kit (5a - 5b)
the protective cap is crimped and i don't know how to get it away. Have to simply pull the cap out ? When it will be out, the kit gives new yellow flat seal
Manov
manovlov
Post by manovlov »
Does this part tells something to someone ?
Capture d’écran 2022-11-06 à 21.19.50.jpg (25.4 KiB) Viewed 356 times
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 115 times
Post by Goupil »
The only point of this part is to keep people from getting to the ECU (warranty reason, thieves, insurance...)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Has thanked: 2210 times
Been thanked: 1852 times
Wow, never seen that bar on the ECU/TCU cover. Maybe it is a EU thing?
manovlov
Post by manovlov »
manovlov wrote: 06 Nov 2022, 13:05 Does this part tells something to someone ?
Actually, not sure if it's an OEM part...
Goupil
Post by Goupil »
scot850 wrote: 06 Nov 2022, 15:58 Wow, never seen that bar on the ECU/TCU cover. Maybe it is a EU thing?
Could be, I've seen it on a few cars here. Mine had already been messed with so it didnt have it.
I've parted out a 940 where you also had to destroy the bracket security rivets to unplug it from the car.
Maybe it was an emissions control to stop the ECU's being removed and modified? Strange though.
manovlov
Post by manovlov »
The gaskets that go inside the fuel rail are available from Volvo for $6 each. Order now!
manovlov
Post by manovlov »
Considering the shape of the thing, I think it's more of a DIY, the fold of the hoop doesn't really match the fold of the lid.
