Hey guys. I tried some searching but I suppose I don't know how to exactly word my search. I have a 99 V70 T5 with I think is called electronic climate control? It has the duel zone temperature knobs
I noticed a while back that pushing the button for fresh air or recirculation does nothing.
I was thinking I would just take the panel out and see if there is any voltage on the other end of the wire but from what I am finding is this climate control system is way more complicated than it needs to be. I am not even sure where the motor would be.
Do I need to plug my car into a VIDA unit to figure this out or is there a more straight forward was I could go about this?
PS: I HATE automatic climate control systems. I also have this annoying fan noise from the little vent next to the steering wheel. Which I assume is some sort of intake fan to measure the interior air temp. But thats an issue for another day.
Air Recirculation Not Working
- Has thanked: 2199 times
Look at the fresh air intake by the fan. There is a lever on the flap to servo that likes to break.
- C1ph3r
- Year and Model: 1999 V70T5
- Has thanked: 32 times
- Been thanked: 7 times
can i get to that behind the glove box?scot850 wrote: 07 Nov 2022, 14:50 Look at the fresh air intake by the fan. There is a lever on the flap to servo that likes to break.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
You have to remove the under-tray from the dashboard. To do that you have to remove the glovebox as the screws holding it in place are behind the glovebox insert.
I'm not sure if you will be able to see the the actuator arm from underneath or not. I'm not limber enough to try! However, to replace the arm (assuming it is broken) will require removing the glovebox and under tray.
The actuator arm is the black plastic rod on the LHS of the white plastic casing for the cabin fan motor and has the white piece with the brass colored rod at the bottom.
Make sure if you have to replace it, which position the servo motor is in or it may jam or break the replacement. You can do that by operating the cold air flap via the ECC unit.
Hope this helps.
Hope this helps.
- C1ph3r
Thank you so much for that. As soon as I get the chance I’ll take a look and see.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
To fit a replacement rod, you have to remove the servo motor. You have to remove one T10? small Torx screw at the front of the motor and it should slide out. Remember to check the movement of the servo to make sure you fit the arm in the correct position to allow the main cold air flap to open and close correctly. This is assuming this is the issue and not a bad servo motor!
- C1ph3r
So I found that the servo arm was disconnected at the servo. I could operate the vent arm by hand and it seemed fine in both directions. The servo also seemed to move fine in both directions until I reconnected the arm.
It closes the vent to recirculate setting fine but when setting to fresh air it takes a really long time and seems to stutter. I’ve attached a quick video I made.
Does this mean the servo is bad? If so, how in the world do I get the old one out and where in the world do I find a new one.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Mine doesn't hesitate when it swings back towards the firewall. I did notice that blower speed selection does effect how far it moves.
Unfortunately, when I select recirculate while on the highway, the pressure forces air through the flap and it whistles. I don't think it closes all the way to begin with. Maybe it needs to be adjusted electrically? I just live with it. I don't use recirculate that often any way.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- C1ph3r
interesting. makes me think my servo is indeed bad then. i use the function a lot in all my cars. usually set to recirculate. and I hate this auto climate control mess. volvo seems to think this can cause an increase in carbon monoxide inside the car and forces the fresh air vent to be open by default. according to the owner manual anyway. safety first454cid wrote: 08 Nov 2022, 11:54 Mine doesn't hesitate when it swings back towards the firewall. I did notice that blower speed selection does effect how far it moves.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
454cid
I have the manual controls in my 850, so there is a difference there.C1ph3r wrote: 08 Nov 2022, 12:31 interesting. makes me think my servo is indeed bad then. i use the function a lot in all my cars. usually set to recirculate. and I hate this auto climate control mess. volvo seems to think this can cause an increase in carbon monoxide inside the car and forces the fresh air vent to be open by default. according to the owner manual anyway. safety first![]()
I JUST picked up an S70 today that has the auto system, and I'd be happier with manual.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 1111 Views
Last post by alschnertz
- 438 Views
- 980 Views
- 19 Replies
- 4162 Views
Last post by JRL
- 33 Replies
- 4822 Views
Last post by PeteB
