Oetiker Oetiker Oetiker
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Paging Professor Abscate. Professor Abscate, please come to a white paging telephone......
You often read to us from the Book of Oetiker (does that sound like a Norse god?), but I have questions -
I went to do a bit of reading, and LO, I find that there are many types and variations. What's a schmuck to do?
https://www.oetiker.com/en-us/Products/Clamps-and-rings
Which is the basic clamp for what we do here? And you've also mentioned a pliers that go in straight or at 90º. Can you recommend a good one? My immediate task/need is the oiler cooler lines on the 850, per this member's fine write-up.
BlackBart
Post by BlackBart »
As an aside, look at this -
"Knipex quality, Made in Germany."
Then go to the Specs at the bottom -
"Made in China."
https://www.amazon.com/Knipex-Tools-10- ... 56788&th=1
Has thanked: 2212 times
Been thanked: 1853 times
I have managed to collect few tools over the years for oetiker clamps. I have a pair of Knipex with the front and side crimp. That has come in handy over the years in tight spaces!!
I have to laugh at the description though!
I prefer to use what the manufacturer uses but have had to succumb to using a good quality pipe clamp on occasion as Volvo have had the wrong part listed for the job being done!
Has thanked: 1613 times
Been thanked: 4075 times
BlackBart wrote: 08 Nov 2022, 16:23 As an aside, look at this -
"Made in China."
Best part of that description
“‎1 Unknown batteries required.”
I have that front side Knipex tool and it is really a good one for my favourite clamps.
Standard oetikers from Belmetrics should be fine for those oil lines. 250 psi is nothing.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Hmm my pliers have a sort of “stop” to so that when clamps are tightened the ear stops rising up. Those pliers just look like a pair of hoof pliers? I'm not sure that’s the correct english word for it. It’s probably enough to just use a pair of wirecutters though.
BMW 540i 2002
S70 Base 2000
BlackBart
Post by BlackBart »
OK, I’m seeing Knipex and Belmetrics in older posts on this. Belmetrics is a clamp source as well? It seems you can buy directly from Oetiker?
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I've got some large nipper style cutters, from Harbor Freight, that I used when doing nylon fuel lines. They worked well, but I did have to be careful not to cut through the small clamps.
I think this is what I have: https://www.harborfreight.com/10-inch-h ... 38496.html
They're cheap, but quite handy. I've used them to cut wire fencing when building compost "bins" for yard waste, and for trimming up nylon zip ties.
If I start buying Oetiker clamps, I think I'll buy something specifically for them. That probably won't be until I have to do a PCV system, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
The correct tool also flattens the top of the crimp to make it sit flatter. I believe this also makes the grip stronger.
BlackBart
Post by BlackBart »
“Stepless ear clamps”
viewtopic.php?t=100647
BlackBart
Post by BlackBart »
