Welcome to our work north of the 49th! Actually we have gone tropical today with a forecast +4C!
- Has thanked: 2209 times
- Has thanked: 1611 times
- Been thanked: 4072 times
Clutch on, m56 on, engine up , up and in…..
Yeah, that would have been a really bad dayvolvolugnut wrote: 14 Nov 2022, 18:35This reads like it did not dump fuel on the ferry. Which might cause lots of excitement.abscate wrote: 14 Nov 2022, 16:39 Bad day for the Kat
Went to board the ferry and something let go in the fuel system above the tank
Had to flat bed to indie as I’m 150 miles from garage
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Spill in aisle 2 ! That's quite a gusher, especially at $4/gal.abscate wrote: 16 Nov 2022, 04:57Yeah, that would have been a really bad dayvolvolugnut wrote: 14 Nov 2022, 18:35This reads like it did not dump fuel on the ferry. Which might cause lots of excitement.abscate wrote: 14 Nov 2022, 16:39 Bad day for the Kat
At least none of the fasteners are gunky.
There is nothing quite like a fire at sea to get your attention. I would rather not tell how I know.
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Do you have an Abscate Blue chase car following you around?
Did the flatbed guy have concerns about fuel dumping over the sides?
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Hit the MAF sensor with some CRC cleaner for maintenance purposes. Checked oil and it was still in the good and not being consumed. Fixed a connector on a headlight so all 4 lights are now going (2fogs 2 mains). Going to clean my partners MAP sensor soon with the same cleaner.
2008 S60 2.5T Auto (Sold)
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Looked under Blue Steel’s hood to check the coolant level and saw these cracks where I’d seen some weeping over the summer.
Why hasn’t it leaked? Can I JB Weld it, or is it an urgent replacement? I’m guessing the latter.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
duckhunt
- Year and Model: 1999 V70
- Been thanked: 4 times
Did you feel any difference from the MAF cleaning? I don’t believe mines ever been done.
I did nothing to my V70 today, except drive it!
It was the first longer journey, 150 mile round trip since doing a fair bit of engine & suspension work with refurbed 16” steels, Michelin crossclimate 2s and an alignment. I really appreciated how different it felt to a month before, smoother engine and stable, solid ride. It felt great to drive and that’s what it’s all about at the end of the day!
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 674 times
- Been thanked: 164 times
I wouldn't run the risk to see the situation to deteriorate further. I suppose JD Welt is a type of cold weld. My car has 23 Yo. To me, each part touched needs to be replace. But the budget is also to keep in mind. To me, I would replace it. Difficult to do some "new" with some "old"...brunocerous wrote: 19 Nov 2022, 15:30 Looked under Blue Steel’s hood to check the coolant level and saw these cracks where I’d seen some weeping over the summer.
Local travel only Bruno. That white residue has plugged the cracks but the if that lets go there will be a big coolant loss
Definite;y gorp someJB on each crack to get through the holiday week(s) then reward her with a new Nissens ftom FCP and two new radiator hoses. Do you want some cool kid oetiker clamps so you can gloat over your uneducated brother?
