I have a manual 95 850 glt. I’m swapping in the turbo motor from an auto T5R. I moved over motor, ECU, dash wiring, cluster from the donor car minus the auto wiring and TCU. I’m getting a no crank and I think it might be because the ECU is looking for the park/neutral signal which it’s not getting because my wagon is manual and none of the wiring is there. I can’t just jump pins on the auto harness. My thought is to try and jump pins wherever the auto harness goes to from the Center console. Where does that harness go to? Is there another way to get the ECU to think it’s in park/neutral? Does anyone have wiring diagrams for both cars?
Thanks in advance!
1995 850 “manual” swap help
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Google "1995 Volvo 850 wiring diagrams".
You'll find what you need.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Everybody's friend Robert may talk about it in one of his swap vids. See if this helps from V/S:notavolvoguy wrote: 26 Nov 2022, 10:37 I have a manual 95 850 glt. I’m swapping in the turbo motor from an auto T5R. I moved over motor, ECU, dash wiring, cluster from the donor car minus the auto wiring and TCU. I’m getting a no crank and I think it might be because the ECU is looking for the park/neutral signal which it’s not getting because my wagon is manual and none of the wiring is there. I can’t just jump pins on the auto harness. My thought is to try and jump pins wherever the auto harness goes to from the Center console. Where does that harness go to? Is there another way to get the ECU to think it’s in park/neutral? Does anyone have wiring diagrams for both cars?
Thanks in advance!
http://volvospeed.com/vs_forum/topic/11 ... ring-help/
And he could cover it here, even though it's not what you're doing:
You didn't mention the year of the donor car, please tell us it's not a '99+.
notavolvoguy
- Year and Model: 1995 850 glt
Donor car was a 96.
I’ll check out Robert’s stuff. Thanks!
- Has thanked: 2857 times
- Been thanked: 1332 times
Look through these results: search.php?keywords=swap+TCU
I know we've covered this, but I didn't look through those results to find where.
- Chuck W
He said the donor was a T5R, so a '95 as well.foggydogg wrote: 26 Nov 2022, 19:21 You didn't mention the year of the donor car, please tell us it's not a '99+.
- 2239 Views
Last post by skloon
- 1286 Views
Last post by bmdubya1198
- 1585 Views
Last post by yanga001
- 9 Replies
- 1493 Views
Last post by dairyqueen814
- 419 Views
