Power Steering Pump pulley
Dave0304XC
- Year and Model: 2003 XC70
- Been thanked: 3 times
Hello, 04 V70, 2.4, my power steering pump is groaning when I turn the wheel, figured I needed a new pump. Easy enough switch out. Ordered a TRW pump from a major online supplier out of Connecticut, got the pump with pulley, pulley is almost 1/2" larger in diameter. Tried mounting it up, but couldn't get the belt on (cause pulley is so big I figured). The online retailer said that's just how they come and that I (???) should switch out the pulley. Yeah that's their solution, I should switch out the pulley. I don't even have a puller. Has anyone purchased a PS pump with the correct (I measured 5 1/8") diameter? Where should I look? Thanks!! Dave
- Been thanked: 4071 times
Dave..try seating the belt into the PS pulley and putting the last loop onto the idler instead
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Hey Dave.. I had the same issue with my 2004 v70 R.. the power steering pump pulley was smaller on the R than another one I pulled from a 2.5 turbo. I just got the longer belt. Secondly, the whining can be coming from the reservoir.. if it's bubbling while idling.. replace reservoir MDK
Dave0304XC
MDK- well it only whines when I'm actually turning the wheel. I heard that's the sign of a bad pump. I will look inside the resivour while it's running see if im getting bubbles. D
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
or low fluid level.Dave0304XC wrote: 26 Nov 2022, 14:32 MDK- well it only whines when I'm actually turning the wheel. I heard that's the sign of a bad pump.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Here's what causes the fluid to aerate and cause pump noise, the return tube inside the PS reservoir cracks.Dave0304XC wrote: 26 Nov 2022, 14:32 MDK- well it only whines when I'm actually turning the wheel. I heard that's the sign of a bad pump. I will look inside the resivour while it's running see if im getting bubbles. D
If your PS reservoir is bad and based on my experience I'd recommend buying a Volvo genuine part or Vaico brand part (FCP EURO and RockAuto have them), the other aftermarket reservoirs I've purchased had a short lifespan.
Dave0304XC
Wow! That's amazing. Would NEVER have thought a failure like that could happen. But, my V will be 19 years old in 2023, and plastics do break down. D
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Thats why any model below 2005 I recommend upgrading to the 2005+ reservoir style. Did it on both my p2’s. Easy swap out
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 1524 Views
Last post by XC70Rider
- 4787 Views
Last post by sventastic
- 2556 Views
- 832 Views
Last post by oragex
- 1017 Views
