P80 P2 seat leather question (Pass to driver skin swap)
Daver1100RT
- Year and Model: 2003 XC70
Hi, original poster here, I don't know how the title changed, but this is not a 2003 S70, I think its a 1999. Haven't bought the car, might look at it this weekend. Dave
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 27 times
The bottom is easy, just snaps to ribs on the cushion and plastic clips hold down the edges. The back skin is held with medal rings to the cushion. I had to cut the rings to remove the skin, bending might be an option but the metal is very hard. I think they are called dog rings, so if you have to cut them you can buy replacements.mark99tj wrote: 20 Dec 2018, 13:04 What is involved with taking the skin off? My driver bottom has come apart at one of the seams, and I would rather take it apart and sew it back instead of waiting for it to deteriorate more.
Important note: To remove the back skin you must remove the head rest. There are hidden bottom on the back of the seat that you push to remove the headrest. Google for where to press.
- SuperHerman
- Been thanked: 207 times
They are called "hog rings". You can pick them up at most hardware stores, and you will need a hog ring pliers. Bring some of the used ones in so you can match the size. They can be easily removed by cutting them with a wire snip pliers.
If you don't want to purchase anything, the hog rings can be expanded, rotated so they release, and then reused by clamping back (bending) to closed with a needle nose pliers. Lots of work, but on my first seat project that is how I managed.
Some have gotten by by using zip ties, trimmed to fit and rotated once installed.
Some idiot moderator probably inferred it from your profile without checking, then edited the title. We will check the logs and relegate him/her to looking for heated third rear seatsDaver1100RT wrote: 20 Dec 2018, 19:20 Hi, original poster here, I don't know how the title changed, but this is not a 2003 S70, I think its a 1999. Haven't bought the car, might look at it this weekend. Dave
The thread links above have some references to both P80, earlier, and P2 , later , car seats
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
velorider wrote: 20 Dec 2018, 23:24The bottom is easy, just snaps to ribs on the cushion and plastic clips hold down the edges. The back skin is held with medal rings to the cushion. I had to cut the rings to remove the skin, bending might be an option but the metal is very hard. I think they are called dog rings, so if you have to cut them you can buy replacements.mark99tj wrote: 20 Dec 2018, 13:04 What is involved with taking the skin off? My driver bottom has come apart at one of the seams, and I would rather take it apart and sew it back instead of waiting for it to deteriorate more.
I think you are describing a 2004up seat. The 2001-2003 are different the way it's attached. While there, those headrests are not fun to remove, a helper is a big plus, plus those releasing clips are fun to find
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Putting seat covers on my 05 XC90 last night and thought I'd add a screenshot/link to save a youtube search. Thanks as always Peppermint!
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 3574 Views
Last post by Cookeh
- 48 Replies
- 97596 Views
- 38 Replies
- 57960 Views
Last post by RickHaleParker
- 15 Replies
- 9625 Views
Last post by E Showell
- 20 Replies
- 13069 Views
Last post by azureblue
