MVS Buddy Project
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
manovlov wrote: 27 Nov 2022, 13:01 So.
I've found this part ("C") Secondary Air System Control Solenoid Air Pump Valve Sas on the diagram upper, from it I have a hose that links "22" on the diagram, and I have to find where this cruise control vacuum servo is located ? :
It's EGR valve solenoid...part # confirms that.
https://www.skandix.de/en/spare-parts/e ... e/1067318/
On earlier models...solenoid was used for EGR valve...on later models it was used for SAS valve.
So...on later models(M4.4) it is located on fan shroud and was used for SAS system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Has thanked: 673 times
Been thanked: 163 times
Post by manovlov »
... and the winner is ...
Capture d’écran 2022-11-27 à 20.17.47.jpg (44.18 KiB) Viewed 323 times
well hidden under the intake manifold. Left hand, the part that was stayed on the V.I.S.V.S. under the intake manifold , on right hand the hose to connect. I've succeeded in plug it in again, but i need to replace that gummy part quickly. I have to see if the part is available or just the end in gummy.
Oh Guys, thanks thousand time for yours advices and helps, Neil, Misha, abscate... You're Gentlemen !
Manov
Has thanked: 2200 times
Been thanked: 1852 times
Yahoo! Glad you found it in the end! Most frustrating I know.
manovlov
Post by manovlov »
impossible without your help...
Don't want to see you driven to drink too much wine! :D
Glad we could help.
manovlov
Post by manovlov »
next issue ! :D
Skandix says this part fits for my 850, and Volvo web store says no. Who to believe ? Is it the right part ?
Capture d’écran 2022-11-28 à 20.23.16.jpg (42.58 KiB) Viewed 307 times
misha
Post by misha »
A '95 with LH 3.2 Jetronic and...of course...VVIS.
I completely forgot about VVIS.
So...the same solenoid with same part # is used for EGR,SAS and VVIS.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
Hey Misha, i was in trouble and you've tried to give me some tracks to follow ! Don't worry, i couldn't succeed in solve this issue without your help !
misha
Post by misha »
You nailed it.
I missed VVIS.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
I've ordered connectors to my Volvo dealer. Hope they are still available. Maybe on Friday. But i will dig this subject deeper. I want to understand what is this system for and what is the goal from each part ( excepted the obvious ones). I'm here to learn...
Capture d’écran 2022-11-26 à 18.26.46 2.jpg (39.44 KiB) Viewed 281 times
