Steering 2004 XC70
goldxc70
Year and Model: XC70 2004
Has thanked: 27 times
Been thanked: 3 times
Steering 2004 XC70
Post by goldxc70 »
Pulling away from a stop, the steering suddenly feels light and "wants" to pull to left. After a small adjustment/turn to right, everything is fine again. Never seems to happen at other speeds.
Alignment was checked and adjusted during summer and no other issues were reported at that time.
Lifted front end and checked wheels for play but couldn't feel any.
Any ideas?
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Do you suppose it's something to do with the upward movement of the front as you pull away? A tie rod or ball joint problem? Something is binding until it settles.
goldxc70
Post by goldxc70 »
BlackBart wrote: 29 Nov 2022, 15:32 Do you suppose it's something to do with the upward movement of the front as you pull away? A tie rod or ball joint problem? Something is binding until it settles.
Hadn't thought about upward movement as it doesn't happen immediately as I pull away. It's just a vague feeling that goes away as suddenly as it comes. If I don't correct, car goes very slightly to left. The vague feeling is more frightening that anything else.
BlackBart
Post by BlackBart »
Or....a component failing, allowing the tire to toe out and pull to the left?
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
i’ve had three steering issues on my xc.
1) notchy steering. Like deadspots kind of that notch back and forth on the wheel if you hold it at a certain position- cause- steering rack
2) binding tough steer-cause-lower u-joint
3) oversteer and erratic steering kind of like you explain- cause- spring seats
I remember an old JRL post (rip) where he mentions that bad spring seats basically cause your vehicle to constantly go out of alignment. I’m wondering if that’s your issue or potentially that upper strut mount bearing
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
my front end tended to hunt on acceleration, it was worn control arms allowing torque steer..
goldxc70
Post by goldxc70 »
br0dy519 wrote: 29 Nov 2022, 20:19 i’ve had three steering issues on my xc.
It sounds like 1. I'm wondering if this has to do with the speed-dependent power steering assistance that some of these cars have.
Not 2 as there is definitely no binding.
I redid the entire front suspension a few years bad. Initially, I used speedy struts by Sensen (through RockAuto) but they were absolute crap. Replaced them with Sachs OEM.
br0dy519
Post by br0dy519 »
My XC doesn’t have variable assist but you’re in the realm of the symptoms I had. It felt exactly what I would expect of a variable speed system gone bad. But my rack was completely hydraulic. It ended up blowing both a seal at one of the boots and the pinion seal. Easy to see if you have variable assist as theres an electrical connection to the rack near the pinion. I have a feeing jonesg maybe the most correct here, maybe combined with a notchy rack. check your ctrl arm bushings too
04s60 2.4
04xc70 2.5t
BlackBart
Post by BlackBart »
We had a steering rack fail on an old BMW my son and I rebuilt. It would bind up and pull this way or that. But it was totally binding - you would push against solid resistance in the wheel that felt like the steering had locked, then it would let go. Scary.
Check the fluid in the power steering system? Any whining in the PS pump?
I like jonesg's idea of the lower control arms moving out of their arc which lets the toe change randomly. A bad tie rod end would do that as well.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
jonesg wrote: 30 Nov 2022, 06:30 my front end tended to hunt on acceleration, it was worn control arms allowing torque steer..
My experience also.
