I am finally saving money for a new Volvo. I can't confirm it'll be a redblock, but I strongly desire a rwd. I have a hitch for a 240 but it doesn't fit a 740. I want a minimum of a 740 for better driving. Im hesitant about getting another 960 because the heater core is a pain to replace. Maybe get a 7/9 and fabricate to drop in an i6 (400hp?)? I have thought a lot about and have wanted to rebuild a redblock for ~300-350hp. I decided to find shops that did such things.
Issue: iPD said they no longer did that and advised I call another shop. I called that shop who told me they no longer do that but did answer my question about a 6 speed manual. I talked to another shop that answered all my questions. This one advised me an NA (my original desire) would likely be unable to reach that. He said that even in a turbo configuration, it would still be a challenge. He advised I go with the whiteblock in the 960 to get better results.
I know some guy on YT rebuilt and put in his 240 a 2.9L @320hp (320lb ft tq?). Thoughts on redblock power capability?
Edit: I did a bit of searching. Heater core replacement on 740 is the same as 960. If the 240 is different from 7,9 series, how much easier is it for 2 series? So many threads on here and a wild goose chase on the right post.
Need accurate info on redblock and rwd whiteblock power limit for daily driver
- CIK7
- Has thanked: 329 times
- Been thanked: 87 times
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Don't know about the heater core, but I put two blower motors in 240s, first one took ten hours, the second - and the last I'll ever do - took just under eight, which is about factory book time. Unless the core goes through the firewall the other way, I'm guessing you have to get the blower out first before you can touch the core.
If you're going to build a hot rod, my suggestion would be to get the body style that fits your performance vision, find the nicest one in your budget, and take whatever the car gives you for maintenance issues.
- Has thanked: 1506 times
- Been thanked: 3822 times
And remember that money spent on performance is at best recoverable at 20 cents on the dollar. It’s fine to spend money on your passion but realise it goes up in smoke on install.
- BlackBart
- Has thanked: 927 times
- Been thanked: 885 times
My thought is that 200-250 is max for a ‘daily driver’ NA. You’re up to the bleeding edge of reliability past that. It won’t be reliable, it won’t last long, it won’t be tractable and calm in traffic, and it might just blow up.
The collector guys all get hot for the early Porsche 911S, rather than a base ‘T’ or an ‘E’ model. But from what I know the S is a pain in the ass to drive every day - it needs to be wound way up in the rev range to make enough torque to slip the clutch. That’s the way all the high performance NA engines act - the horsepower is way up past 4000, 6000 rpm. It’s only fun on a race track or an empty mountain road.
I think the twin cam, 16 valve, Volvo 4 cylinder can make quite a bit of NA power, but I don’t know how high or how reliable.
My Audi 1.8 turbo makes 180 hp. The hot rodder tuner guys build them up to outrageous 400, 500 hp. But they are a massive expense of custom forged rods and pistons, BIG turbos, a ton of handmade exhaust and intake plumbing, electronics, and giant intercoolers hanging off the front. And they’re no fun to drive except for that brief Saturn V launch in the power band.
- Has thanked: 928 times
- Been thanked: 1002 times
The old saw always applies: "Horsepower costs money. How fast do you want to go?"
I would add: The cheapest horsepower seems to be made by NA with big displacement. The huge V8's of the 1960's were relatively cheap to buy. But they also burned lots of gas even loafing along.
- Has thanked: 2656 times
- Been thanked: 1248 times
I'd build a nice 5-cyl whiteblock turbo on a stand and put it in a 700- or 900-series, if I was going to go fast in a RWD Volvo.
- CIK7
A 5cyl in a rwd? Has anyone done that? I'm kinda bummed out after I was told that even the turbo 4 can't go too high. I really kinda want another wb 6cyl. I just hate the heater core replacement. It was really easy on the p80 cars but they've got crowded engine bays. I will admit I miss my red v70 5sp. This car shopping is stressful.
Have you considered an LPT white block?
I love the way Kat comes off the line, amd she gets me high 20s gas mileage , almost 30 highway
Kat 99 S70 AWD with LPT
It’s real cheap to pry off the AWD label and put an R on it and tell everyone you can beat them if needed
- 9 Replies
- 4983 Views
Last post by BlackBart
- 813 Views
Last post by volvolugnut
