Much like the rear deck speakers in my 850, the dash tweeters in my car were also totally shot, and I didn't want to waste my money on more crappy junkyard replacements. Luckily, unlike the rear deck speakers, there was a precedent for replacing the dash tweeters that got me started:
https://www.swedespeed.com/threads/volv ... er.620937/
https://volvoforums.com/forum/volvo-850 ... ent-97206/
However, the speaker recommended in these threads is no longer available to purchase from what I could find. So, I turned to Parts Express once again and settled on these 2" full range drivers and some 3.3uF capacitors to ensure that they only play frequencies which they're well-suited for (the stock capacitors are also 3.3uF).
I didn't take a bunch of pictures like I did with the rear deck speakers because this project is really quite straightforward. I ultimately just decided to hot glue them into the old speaker mounts, but there are a number of different ways you could approach mounting them. No, it doesn't look the best, but you can't really see them under the grilles anyway.
The verdict? These sound PHENOMENAL. Unlike the 6" rear deck speakers which are sort of a "these are the best you're gonna do given that the OE speakers are a nonsense size", these are a genuine upgrade over the original speakers and provide a substantial increase in clarity over the crappy OE paper cone units.
Another 850 speaker upgrade - dash tweeters
- slickdizzy
- Year and Model: 1996 Volvo 854 R
- Has thanked: 9 times
- Been thanked: 15 times
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
As I'm not a audiophile, why do you need the capacitors ? Are they installed to limit the speaker to more of a tweeter than mid range ?
Will the speakers work fine without it ?
I have everything on hand to do this mod, but just like knowing what I'm doing, and why.
1999 V70 GLT
1999 V70 GLT
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
This looks like a good cheap upgrade, these seem quite similar to the shape of the V/S/C70 ones as well. Adding this on the list of things to do
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Factory setup on tweeters also have capacitors.Sveedy wrote: 04 Dec 2022, 08:08 As I'm not a audiophile, why do you need the capacitors ? Are they installed to limit the speaker to more of a tweeter than mid range ?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- slickdizzy
The capacitors prevent that little 2” driver from trying to play the entire audio frequency spectrum and instead limit them to higher frequencies. The speakers will work without the capacitors but they will sound poor when trying to produce bass/midrange notes they are not appropriately sized for.Sveedy wrote: 04 Dec 2022, 08:08 As I'm not a audiophile, why do you need the capacitors ? Are they installed to limit the speaker to more of a tweeter than mid range ?
~Desmond (Current: 1996 854 R, Past: 1998 V70 GLT, 1997 855 R, 1988 744 Turbo, 1993 965)
- Sveedy
slickdizzy wrote: 04 Dec 2022, 14:43The capacitors prevent that little 2” driver from trying to play the entire audio frequency spectrum and instead limit them to higher frequencies. The speakers will work without the capacitors but they will sound poor when trying to produce bass/midrange notes they are not appropriately sized for.Sveedy wrote: 04 Dec 2022, 08:08 As I'm not a audiophile, why do you need the capacitors ? Are they installed to limit the speaker to more of a tweeter than mid range ?
Thanks much ! Exactly what I was wondering about.
1999 V70 GLT
1999 V70 GLT
- 1818 Views
Last post by MrAl
- 3236 Views
Last post by mrbrian200
- 4585 Views
- 4508 Views
Last post by kallekula
- 1654 Views
Last post by kridronoa5
