Volvo's 5 cylinder engine is an open deck construction, its cylinder sleeves eventually get a taper towards the cylinder head, which forces compression rings to open wider in the upper part of the sleeve. Also the rings themselves are likely worn, not very elastic and the gap is too large, to begin with. Also the sleeves are out of round, which causes all the rings to orient in such a way that their thermal gaps are aligned in one line. That's really bad for the crankcase blow-by gases (PCV has to work harder), as well as it allows much more oil be sucked in during the intake stroke.
No cure, except replacing the piston rings with new ones. And yet this is not a long term solution, because of taper and general bore wear.
This engine is good, but not worth rebuilding without a significant construction change at high mileage, like Darton sleeves, in my opinion.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
That's really interesting, what causes that? Is it temperature at the top of the cylinder? Erosion from combustion?vtl wrote: 07 Dec 2022, 08:24 Volvo's 5 cylinder engine is an open deck construction, its cylinder sleeves eventually get a taper towards the cylinder head, ....
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Thin cylinder walls in 2.4 and, especially, in 2.5 that don't hold well a naturally higher pressure in upper part of the combustion chamber. Add occasional detonations.BlackBart wrote: 07 Dec 2022, 10:28That's really interesting, what causes that? Is it temperature at the top of the cylinder? Erosion from combustion?vtl wrote: 07 Dec 2022, 08:24 Volvo's 5 cylinder engine is an open deck construction, its cylinder sleeves eventually get a taper towards the cylinder head, ....
vtl
Yeah. This is what Volvo permits:
This is what engine from the donor car w/ 220k miles on the odo had (I was swapping out crashed chassis and took its working engine apart out of interest):
Out of round 2 is near the top of the bore, 1 is around the center.
Willber
- Year and Model: 2.4t 2002
- Has thanked: 5 times
Thansk, vtl, really interesting!
Do you think that my smoking is probably piston rings rather than stem seals or valve guides then, if it only occurs after long periods of high vacuum / engine braking, rather than after idling or upon start up?
vtl
Likely, both. It is a good idea to replace valve stem seals, though. At this age/mileage they are long time not elastic and badly worn.Willber wrote: 08 Dec 2022, 07:32 Thansk, vtl, really interesting!
It is not an easy job to do with the engine still in the engine bay. Exhaust valves are barely accessible, you must drain oil from the camshaft valleys and degrease valve guides with acetone super-thoroughly, otherwise the new seals will fly off.
Also exhaust seals better be Volvo original. Others commonly fail in 20-30k miles. Intake could be Elring. I personally put OE/exhaust (very expensive) and Elring/intake.
