850 1995 Idling up and down Topic is solved
Has thanked: 1853 times
Been thanked: 1714 times
Re: 850 1995 Idling up and down
Do you have the owners hand book? I think it was written in there, but I may be wrong. Sorry been about 10 years since I had a 850 with that unit on it.
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
scot850 wrote: 10 Dec 2022, 10:32 Do you have the owners hand book? I think it was written in there, but I may be wrong. Sorry been about 10 years since I had a 850 with that unit on it.
Yes i do. I will try to reset codes and post it about tomorrow ( or any result anyway).
manovlov
Post by manovlov »
No comment...
manovlov
Post by manovlov »
I've replaced the Idle Control Valve yesterday and things started to come to normal. But, after have waited 15 mn idling, the coolant gauge, to the top, came to the bottom and get again to the top. The ODB gives me wrong information. Approxymatly, each 5 minutes, i loose 10 km of autonomy, which is wrong. The last time i did a long trip (2 weeks ago) it was the case, but after 1/2 ho on the motorway, this information started to grow up again. May be i should drive a bit, following Misha's idea, to let the control unit retrieve its normal data.
This morning, i started the car, it got to its normal gauge level on the speedometer, but the announced consumption drops from 10 km regularly. Then engine stopped as if it was running out of air.
What i know :
- the coolant sensor is new,
- the thermostat coolant is new
- the Idle control valve is a "used" part,
- Cam pulse sensor is new,
- i'm gonna replace the throttle position sensor (BOSCH) (replaced the inside seal btw)
- The throttle bdy has been cleaned up, new paper seal,
Tracks :
- Oxygen sensors (both) ?
- Knock sensor under the intake manifold ( ground fault) ?
- Distributor cap (which have been replaced in 2019) ?
- The MAF (one is on its way with abscate help.
What is this part for ? Has it something to matter with the Idling ?
Knock sensor.jpg (18.02 KiB) Viewed 370 times
Manov
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
manovlov wrote: 25 Dec 2022, 02:50 ... But, after have waited 15 mn idling, the coolant gauge, to the top, came to the bottom and get again to the top.
Ect or it's wiring are bad.
Ect being bad...the engine ecu doesn't know what is the engine temperature and don't know how much fuel to inject and engine can stall,cut out or will not start.
Driveablility and engine running is compromised.
More-less...the symptoms you have.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
Thanks Misha. I will do a drive test tomorrow. I think that to have used a bad idle control valve may have send wrong data to the ECT. After have driven 200 miles before the new issue, everything was fine. To drive for 100 kms should bring back ECT to reason...
misha
Post by misha »
When engine is idling...ect sends signal to ecu and then ecu sends signal to iac valve for idle speed.
Iac valve is active only when engine is at idle &
gas pedal at rest...as soon as you press the gas pedal iac valve is closed and throttle plate takes the induction of air to the engine.
TPS sensor is there to tell the ecu how much throttle plate is open(what is engine load) and ecu knows how much fuel to inject depending on engine load.
On closed loop engine gets paramaters from MAF,ECT & o2 sensors....again TPS is there to tell ecu what engine load is.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1506 times
Been thanked: 3820 times
Get that throttle body shiny clean , all that oil and grime should be removed!
Your MAF is slowly making it s way through our clogged Christmas mail system
manovlov
Post by manovlov »
Salut abscate,
I should receive a brand new "used" one...
Done.
Cleared customs this morning! If you use WhatsApp,I can send you the link to tracking by phone ( or use email)
