In my 1995 855, the ground wire bullet of the OBD port/module (under the hood) was broken off. I tried to find a replacement part from dealer and online, no luck.
Do anyone know where I can buy a replacement ?
Thanks,
Ching-Ho Cheng
1995 OBD port/module wire bullet broken
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
Thank you for the reply. However, the broken piece was the plastic white color bullet itself. It broke right at the point where the black ground wire met the white plastic. There was no soldering that could be done to reconnect the wire to the plastic bullet.
- Has thanked: 987 times
- Been thanked: 1075 times
Source the needed part from a salvage yard?
- Has thanked: 2199 times
Sorry we have no junker 850's in the breakers yards up here just now. Sorry!
Robert might be worth a shot on his junkyard tours.
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
Bullet type electrical connector and attach that. Even easier than my process since mine was right at the box. Crimp style or solder. Amazon, Habor Freight, etc. Cheap ass way? strip wire and double up the bare wire on itself to make enough contact between wire and female port.
- 1800 Views
Last post by loveMy850
- 7742 Views
Last post by wizechatmgr
- 1788 Views
- 14 Replies
- 5215 Views
Last post by misha
- 2216 Views
Last post by brunocerous
