Took well over an hour, mostly because I don't bend or fold in enough places anymore, and I was adamant about not pulling the seat out again.
This car is getting towards the end of its string with me.
I'll start a separate thread on trying to fab a fix on the broken piece.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Originally a 5.0 when I bought it back in '96. Been a 2.3T for a long time now, though.
Have a list of projects to go through on it, but it's 3rd in line behind the 850 and the '85 LTS.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
Where did you get the constant tension band clamp for the upper hose?brunocerous wrote: ↑17 Dec 2022, 17:12 I finally undid the two radiator mounting bolts with a combination of a grinder, oscillating tool and drill. It wasn’t pretty, and I’m not proud of what it looked like at the end, but it was a relief. 5F760CFA-0598-4E77-A362-6B9089A9403C.jpeg86AF0006-4A58-44C1-8D53-B43B52345393.jpeg
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1497 times
- Been thanked: 3810 times
You can’t clamp over a paper label, Bruno…it’s …just…..wrong.
- Has thanked: 304 times
- Been thanked: 517 times
I was going to say the same thing... unacceptable!
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
hi most vw dealers have them,there on many vws theres even a vw tool for ease of removal,fitting is easy. audi ones are stainless atleast they where,good luck454cid wrote: ↑17 Dec 2022, 21:01Where did you get the constant tension band clamp for the upper hose?brunocerous wrote: ↑17 Dec 2022, 17:12 I finally undid the two radiator mounting bolts with a combination of a grinder, oscillating tool and drill. It wasn’t pretty, and I’m not proud of what it looked like at the end, but it was a relief. 5F760CFA-0598-4E77-A362-6B9089A9403C.jpeg86AF0006-4A58-44C1-8D53-B43B52345393.jpeg
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
Is that clamp strong enough for the coolant hose? Looks like it could blow right off? I use a rolled edge Norma Torr worm gear clamp for that. No, not Oetiker so I can easily remove it (most important for the lower hose to drain coolant).
FireFox31
454cid
The only time I've blown one off was when I pressurized the system with 60psi from the water hose (city water). If it hadn't blown, I probably would have lost my trucks radiator. I don't recall why I did it, but I was in the process of flushing the cooling system.
They have ears on them, but there's no way you're pinching it by hand enough to remove it. You have to use pliers and its best to use the pliers specifically designed for them.
The really great thing about them is that they adjust for thermal expansion, since they're a spring.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
FCP has the pliers
https://www.fcpeuro.com/products/hose-c ... s-cta-1050
Or you can support MVS via Amazon…
https://www.amazon.com/CTA-Tools-1050-M ... 164&sr=8-1
Great stocking stuffer!
A Thunderbird is roomy , but I don’t think either will fit.Nice, I was thinking I would put my 850 or LeSabre in one.
