2000 V70 missing third gear
Masij
Year and Model: 2000 v70
Post by Masij »
Hi all! I received a Volvo v70 in good condition. the only big problem is the missing third gear. I have already changed the valve body and the B4 valve cap. and of course the transmission oil change. all other gears go smoothly. Do you think there is anything left to do to save this transmission? Thank you in advance for your help.
Volvo V70 T5
Masij
Post by Masij »
I can use Vida. if that can give you more information.
Volvo V70 T5
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Someone touched the third gear band anchor bolt, the band is disengaged now. Normally it warrants a transmission removal, partial disassembly and reinstalling the band. It is possible to hook the band through the B4 servo hole, preload it, a helper person screwing in the bolt.
