Can I Change My Own Voltage Regulator? 1998 v70
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Would this be easy to change or very hard to change?
Thanks.
Been thanked: 4065 times
It’s possible and hard with the alternator on the car.
It’s easy with alternator on bench
It’s imperative you disconnect the battery either way, for safety
MrAl
Post by MrAl »
abscate wrote: 18 Dec 2022, 14:37 It’s possible and hard with the alternator on the car.
Oh ok, i understand. Too bad, i wanted to see if the charging voltage changed with a new regulator.
The alternator does not look too easy to remove, so maybe some day :-)
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
It can be done on the car, but it's much easier if a few things on the front of the engine are removed for access.
Having a "tucked" cooling fan also grants a bit more room.
foggydogg
Been thanked: 405 times
Post by foggydogg »
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I bought a regulator for my 850, but have yet to actually try replacing it. It looks very fiddly due to it's position and things being in the way.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Alternator service is good to consider along with 5 cylinder PVC service.
MrAl
Post by MrAl »
foggydogg wrote: 19 Dec 2022, 09:29
That looks interesting.
Now you are supposed to disconnect the battery, but when you do that you loose the OBDII information memory.
Can you power the computer through the OBDII connector as usual then, or does that also still power the alternator?
If it does power the alternator, is there a fuse you could pull to prevent that?
MrAl
Post by MrAl »
454cid wrote: 19 Dec 2022, 10:40 I bought a regulator for my 850, but have yet to actually try replacing it. It looks very fiddly due to it's position and things being in the way.
Yes it looks kind of tight in there. My old Hyundai was much simpler.
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
