The parts cannon hadn't been invented yet so the poor guy had to throw them manually.
Test aftermarket front seat covers with airbag deployment
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I was cracking up just watching Robert throwing things at it. That alone was worth the time spent.
1999 V70 GLT
1999 V70 GLT
454cid
- Has thanked: 151 times
- Been thanked: 139 times
That was funny. I was not expecting that. I thought he'd trigger it electrically. I didn't know the seats had air bags in them. Is that all P80's such as my 96 850, or just S70s?Sveedy wrote: 16 Dec 2022, 13:22 I was cracking up just watching Robert throwing things at it. That alone was worth the time spent.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Been thanked: 4064 times
1995/6 models depending on market got SIPS including side air bags. Your 96 will have them.
Look down between the driver seat and the plastic trim, just near the knee area for the mechanical actuator. I think they also emboss SIPS into the rocker panel metal
- Has thanked: 987 times
- Been thanked: 1075 times
I want to revisit this post.volvolugnut wrote: 15 Dec 2022, 16:55 Unfortunately, wizechatmgr is right that unless there is some assurance the aftermarket seat materials and manufacturing are consistent, the test would not give the assurance wanted that all seat covers would be safe.
This was a great idea for a test, but a predicable product is needed.
I do not want to discourage this test and recovering seats. I just wanted to point out there may be unexpected future results.
850oldschool
Are you guys really concerned about failure to deploy with that much explosive force behind the airbag? Or do you feel we should design a NHTSA compliant testing protocol?volvolugnut wrote: 18 Dec 2022, 07:43I want to revisit this post.volvolugnut wrote: 15 Dec 2022, 16:55 Unfortunately, wizechatmgr is right that unless there is some assurance the aftermarket seat materials and manufacturing are consistent, the test would not give the assurance wanted that all seat covers would be safe.
Just pointing out there may be seat differences that will make results less than original equipment. If that unknown is acceptable to the end user, then proceed.
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
That video is where I got the idea from. I was initially afraid that the airbag might not punch through the cover, exploding seat material into someone's shoulder. After seeing Robert's video, I wanted to know if the airbag would deploy in the correct size, shape, place as designed for optimal protection.850oldschool wrote: 16 Dec 2022, 09:15 Did any of you guys even watch the video I posted of Robert detonating one of those? That thing went off like a bomb. No combination of leather and thread is going to hold that thing back.
You're unfortunately right. OEM Volvo seat covers would have consistent manufacturing but that's not a guarantee with aftermarket. A cover made a year later might use different thread. I'm uncomfortable recommending that a product is safe when I can't make a reasonable assurance that it always will be.wizechatmgr wrote: 15 Dec 2022, 15:05 The problem is if the aftermarket isn't being designed and built for the side deployment in mind, if not, then production variations could mean some are useful for the purpose and others could possibly not be -- possibly becoming more rather than less of a hazard.
Also, it would be scientific and accurate to detonate an airbag in an OEM seat cover to compare the results. Might not be necessary, but it would set a baseline. Using an old, torn seat cover may skew the result since the tear would give before the stitching did. No, I don't want to use a nice OEM seat cover for the experiment, unless maybe it was damaged far from the airbag site. It may be enough to detonate one with no seat cover on to see its correct shape and location.
FireFox31
- 1868 Views
Last post by otis44
- 7289 Views
Last post by jimmy57
- 960 Views
Last post by dudeitssm
- 1681 Views
Last post by RickHaleParker
- 20 Replies
- 7350 Views
Last post by Klausc
