Question for the pros...
- The 2007 S60 2.5T with 115K miles is about 600 miles away (kid in college).
- I have the "projector style" HL assembly (per @jimmy57's post above).
- If I decide to switch to Halogen type:
1. What is the Volvo PN for the Halogen-type HL Assembly?
2. Is Halogen brighter than Bi-Xenon?
3. Will I get a "Light Failure Message" on the DIM screen?
Thanks!
2006 S60 Headlight problems Xenon - bad ballast
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
1)Right Sidecn90 wrote: 22 Dec 2022, 21:05 Question for the pros...
Thanks!
https://www.fcpeuro.com/products/volvo- ... c-31276808
https://www.ipdusa.com/products/10496/H ... 808-121967
https://usparts.volvocars.com/p/Volvo__ ... 76808.html
Left Side
https://www.ipdusa.com/products/10495/H ... 807-121968
https://usparts.volvocars.com/p/42855866/31276807.html
2) Bi-Xenon much brighter
3)
- MoVolvos
My other go to place with Lifetime Guarantee. Both DEPO & TYC are common aftermarket but not as good as Volvo OE.
$ 364.95 Pair
2007 Volvo S60 Driver & Passenger Side 2 Piece Headlight Set DEPO 1ALHP00816
https://www.1aauto.com/2005-09-volvo-s6 ... 80371/2007
$ 364.95 Pair
- Been thanked: 504 times
So for the 2007 S60 with Bi-Xenon HL, even after I spent hours polishing the lens, the output at night is about 50-60% of what a normal
car should be. My theory is that, even from factory, the 2007 S60 Bi-Xenon light output (mine uses D1S bulb) is below normal.
Then I found out if you flip to "High Beam" you don't blind the car in front (or opposite traffic at all).
I was doing this test at night (with "High Beam" on) and with a friend in the car in front, I did not blind him at all.
So, for my particular 2007 S60, if the output is below normal at night, I use "High Beam", which turns out to be the equivalent of Low Beam in many other vehicles on the road.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Have you verified the headlights are aimed properly? Even a fairly poor HID system performs quite well compared to halogens.cn90 wrote: 29 May 2023, 21:39 So for the 2007 S60 with Bi-Xenon HL, even after I spent hours polishing the lens, the output at night is about 50-60% of what a normal
Adjust the aim up to see if that helps as you did have the headlights out of the vehicle, and polishing/working the lenses may have altered the aim. Hope it helps
2008 S60 2.5T Auto (Sold)
Mike98
- Year and Model: V70 2006 NA
- Been thanked: 4 times
I have a 2006 V70 with factory Bi-Xenon HID. It uses a D2R bulb instead of D1S. The HID design for 2007 S60 must be different than 2001-2006 as the 01 - 06 used a D2R bulb. Volvo factory HID systems were required to incorporate autoleveling. HID autoleveling on P2 cars uses angle sensor(s) in the rear suspension and a motor in each headlight capsule that sets the HID beam angle. The HID headlight capsules have a manual vertical beam adjustment but it only makes a small adjustment in beam angle compared to the leveling motor. The headlight capsule has a separate solenoid that tilts the beam for hi/lo.cn90 wrote: 29 May 2023, 21:39 So for the 2007 S60 with Bi-Xenon HL, even after I spent hours polishing the lens, the output at night is about 50-60% of what a normal
Perhaps the self leveling system isnt working in your S60. The result could be that the self leveling motor defaults to the lowest beam angle. Do you have access to Vida ? It should have some diagnostic information on the self leveling system.
When the vertical beam angle of P2 factory HIDs is adjusted properly, the high beam pattern has long reach but a disconcerting sharp vertical cutoff. Probably Halogen headlight capsules could be substituted in your car, not sure if a fault will be displayed in the DIM. Halogen headlights may consume more power than HID, especially if the Halogen high beam and low beam are both on. There might be some wire gauge differences in the wire harnesses.
2001-2004 P2 headlights used glass lenses. Those lenses arent degraded by sunlight, but the internal reflectors have the same problem as glass P80 headlights - the reflector silvering evaporates and the headlights become dimmer. 2005+ P2 headlights use plastic lenses so those headlights can have lens degradation and reflector degradation. A set of aftermarket halogen headlights might be the easiest solution.
Mike
2006 V70 M56 NA
For projector style Xenon, if the "door" does not lift when high beam lever is activated, is there any DIY addressing this small door?
Nvm,
Found the problem.
The D1S bulb I installed recently...if you ever dealt with it, you will know...it is held (from factory) with metal prong and crazy glue.
The prongs alone are not enough to hold it in place so the bulb came loose!
Anyway, I used the thin wires from Cat 5E Ethernet cables I have lying around. Used one twisted pair of wire, on each side: wrap around the prongs (find a place that it would not come loose, you will see some prongs with an angle, just use common sense). Inserted the bulb, join the 2 ends together and gently twist them. All is good now.
Found the problem.
Bridge2Fairway
- Year and Model: 2006 V70 2.4
I have a 2006 V70 2.4 automatic with standard Halogen headlamps. My headlamps are polished and refaded TYC lamps and passenger side was damaged. I have a pair of the P2 Valeo ABL lamps and would like to install them. The vehicle wire harness plug for the headlamps is the same. I do not have: the rear suspension sensors, steering position sensor, console switch, and I still need to check for the ‘green connector’ under the driver seat where I understand that the ABL module goes. I understand that I there may need to be a jumper harness with a capacitor to send the right signal to the headlamps and perhaps change a wire at the lamp or relay… or maybe change with VIDA..,has anyone done this conversion successfully and is it worth the effort and what are the required changes? or should I sell these lamps and buy standard replacements?
- Has thanked: 2197 times
- Been thanked: 1851 times
What year are the replacement headlights from?
I don't know what ABL lights are? I know Volvo had at least 3 options. Halogen, Xenon, and Bi-Xenon. Bi-Xenon I understood are a 07 on option and do not work with 05-06 cars as they had different wiring harnesses. I think I have read they can work on an 05-06 car but the leveling won't work because the cars don't support it. I'm happy to be corrected.
- 946 Views
Last post by MoVolvos
- 2494 Views
Last post by Icewater66
- 504 Views
Last post by RickHaleParker
- 675 Views
Last post by cn90
- 649 Views
Last post by shmizoke
