Thanks for confirming this. I always wondered if this could be done, but wasn't sure.
- Has thanked: 2203 times
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
XC90 but a P2 nonetheless. Finally had the car long enough to pull the front floormats and inspect the aftermath of sunroof drain issue the previous owner let go. Had to run a heater on the foam overnight to thaw and dry. Forgot to snap an after picture...a coat of corroseal did a nice job sealing up the floor. Thankfully the passenger side (including yaw sensor) was dry as a bone.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
Fortunately just surface rust. These XC90s have the unique opportunity to rust from the inside to out!vtl wrote: 28 Dec 2022, 14:14 Holy Odin! I thought my car (its transplanted donor chassis) was rusty!
When I bought it the a-pillars were pretty bad (now replaced) so I knew I was taking a risk. So far other than replacing the a-pillar and sunroof drain hose only other problem was a connector I needed to wire around.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Replaced all 5 coils with new Bosch units and Volvo OEM spark plugs and got rid of my misfire. I’ll save the 4 good ones for spares. Also changed the oil filler cap seal. PCV system overhaul next when I have some time now that I have all the parts for it.
2003 XC 70 (sold)
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
MDK here. So, I decided to check my spark plugs. I put new ones in about 7 months ago ( I barely got the old ones out) anyway.. I found this on #4 coil wiring assy. Someone had heat shrinked all 3 wires together. I separated them and re wrapped em. Dumped the oil, new 5w30 plus moly lube and filter..
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Was that causing a misfire?MDK wrote: 31 Dec 2022, 15:13 MDK here. So, I decided to check my spark plugs. I put new ones in about 7 months ago ( I barely got the old ones out) anyway.. I found this on #4 coil wiring assy. Someone had heat shrinked all 3 wires together. I separated them and re wrapped em. Dumped the oil, new 5w30 plus moly lube and filter..
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Replaced a seized brake caliper.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Krons
2008 S60 got some attention today. Was a tad slow to start and some stumbles on starting recently. Decided to replace the starter given it has 150k miles and with an online code was only $135 at Carquest for a lifetime warranty starter. Pretty easy access when you pull the intake pipe and spin the air box out of the way. Starts much better now.
While I was there replaced a bunch of brittle conduit wrap on harnesses to keep them out of harms way. Then to prevent any starting issues did the steering lock-ectomy to remove the failure prone steering lock mechanism. Now onto cleanup of the newly acquired 2008 C70…
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
