I have a 2005 S60 with Magnetti Marelli ETM. How can I be sure I have one of the affected models? I have a brand new Bosch MAF(several months old), so I know it's perfectly fine and working.
But I do have a few issues which I am unsure if I should interpret as a failing ETM or just a few vacuum leaks. Basically when driving the car, and I am at a high speed and press the brakes when reaching a stop, the RPMs fall well below 700(750 is my idle) and in fact I dare say they drop to 500RPM and then after a second or two when I am done braking and have stopped, it goes back to 750.
I have also noticed some RPM hunting, but not a huge amount, but the engine noise gives it away more than the needle does.
And finally, sometimes, I am not sure if I am catching the gearbox in the middle of changing gears, but there is def slight hesitation when pressing the accelerator, like a kick to the gearbox.
2005 S60 BiFuel MM ETM priblem
sak54757
- Year and Model: 2001 v70xc
- Has thanked: 3 times
- Been thanked: 2 times
Hi, Over the years I've needed to clean or replace the MAF sensor multiple times, so, even though yours is only a few months old i'd start out by cleaning it. BTW I have have good luck with the Xmodex replacement etm, four years and 50,000 miles...
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
The xemodex thingy costs pretty much as volvo would offer it, especially since they are US based and there is also a hefty 20% VAT on their price. If this was around $200 I might have considered it.
- Has thanked: 2857 times
- Been thanked: 1332 times
XeMODeX is Canadian, although I'd guess their US sales are greater than their Canadian sales.
dikidera
Doesn't change anything though, still on the America(s)n continent. Anyway, I am curious if my description of the symptoms sound similar to a failing ETM?matthew1 wrote: 30 Dec 2022, 11:40 XeMODeX is Canadian, although I'd guess their US sales are greater than their Canadian sales.
- Been thanked: 4068 times
Your 2005 would have a Bosch Electronic Throttle Actuator, not the ETM covered in this forum. It doesn’t fail the same way and is much more reliable
dikidera
Not bosch though, it's definitely marked Magnetti Marelli.abscate wrote: 02 Jan 2023, 23:40 Your 2005 would have a Bosch Electronic Throttle Actuator, not the ETM covered in this forum. It doesn’t fail the same way and is much more reliable
Yagger reminds me Bifuel cars have the MM ETM through the P2 line, was your car ever BiFuel?
They run well for about 250,000 km then need service
- 4556 Views
Last post by ajwsurfer
- 5022 Views
Last post by antonevane
- 15 Replies
- 6815 Views
- 4757 Views
Last post by firstv70volvo
- 712 Views
Last post by oragex
