Strange noises from the timing belt area Volvo S70 98 Base
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
At this point I would probably take the timing belt off and spin the rollers and the water pump by hand and wiggle them. It sounds like one of the rollers to me.
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 04 Jan 2023, 14:23 ...I don't know who supplies or makes the pumps for Gates.
The Gates pump I bought for my 454 was from China and the shaft seal went out in a year or two. I didn't want to find out how long a Gates pump would last on my Volvo.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
luckykolo
Year and Model: s70 1998 Base
Has thanked: 14 times
Post by luckykolo »
Ok, surprise, surprise, tried again at 45F ambient temperature and no noise... or at least nothing exceptional...
I tried to remove the bottom timing belt bracket - 2x bolts 10mm. Managed to remove only one. It had red thread lock on it. Why would these bolts have a red thread lock? The second bolt would not budge. If anything, blue thread lock should be sufficient on it. Hopefully I won't need to remove this shield in the future... I used my endoscope camera to inspect the space, as far as I can tell, nothing in there. The bracket looks solid. The only thing I did was to spray a bit of WD40 on the bracket to help with bolts. I don't see how that could make a difference... Timing belt is clean, I made some picks of timing belt marks. I guess they look ok.
timing belt marks 2 volvo.png (1.38 MiB) Viewed 588 times
Not sure if this looks off, or good enough, or maybe I needed to move the crankshaft a bit more?
This is the top line up corresponding with the crankshaft on the other picture.
Is that acceptable?
​​​​​​​Thanks
Been thanked: 4065 times
Especially if you bumped the 1/4 tooth you are off on the crank, you would pick up the 1/2 tooth you are off up top
It’s fine, run it,
luckykolo
Post by luckykolo »
yep, these 2 notched teeth on the crankshaft are kind of on the edge. I would say that this marking system could be definitely improved, unless it has some tolerance built in to it... I will take a car for the spin today and will see what happens. If I will end up taking off the TB, I will get rid off current one by Gates. It's acting weird from the beginning. It is hanging on the edge of sprockets and travels sideways slightly. Unfortunately instead of doing TB job myself I outsourced it to the local shop in Atlanta and of course their policy is: You use our parts or else...
Thanks for you input!
The policy that is the birthing of so many DIYs
Moving down to North shore Long Island I interviewed four shops who all declined user parts , and then found Munch Auto on 25A who replied…. Let me guess, you know about FCP
Happy to install your parts.
luckykolo
Post by luckykolo »
yes, I know FCP. They are great for the most part. Little issues here and there, but great return policy. Unfortunately it looks like they have less and less parts for my Volvo. I guess there are some junk yards in my area...
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I could imagine the water pump. 20 years ago I had a really weird chirping noise on a Ford Mondeo one morning. A few hours later the water pump drained all fluid safely on the floor.
Didn't we have a photo on here of an aftermarket water pump failing with the impeller blades broken off?
If this were my car I'd pull the TB and replace the water pump with a Volvo or Aisin unit. Just to be sure.
1996 855 R,
2010 V70 D5,
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Just avoid Hepu water pumps. Used to be real crap causing timing belt failures and I doubt the quality has improved. I always by Aisin, they are OE.
BMW 540i 2002
S70 Base 2000
luckykolo
Post by luckykolo »
So far car drives fine - I drove about 300 miles. It makes noises sometimes. No noise once the car is warm. We will see what the future will bring... I am about to do the entire suspension on it. If engine will fail, I will just replace it... Or maybe it will keep chugging along lol
