Hi every one and thank you for helping.
I have a 1994 850 auto sedan which had a new fuel pump and filter installed 10,000km ago, new NGK (triple pronged) plugs 10,00km
ago. it ran fine for a few months then I got an occasional miss under load that has gotten worse each long (600km ) trip until yesterdays trip it is now a constant missfire/lag at all times in all gears and I only just limped home.
I just checked the codes but only a 1:1:4 came up on port A1, I was expecting something to come up on A2 fuel port but nothing.
The car had only done 120,000KM from new.
I read on a forum that triple pronged spark plugs may cause problems and I should only use standard single contact coppers supplied by volvo, any comments on this?
Im suspicous of the $120 after market pump so Im about to go flog the pump top with a hammer to see if it "jogs" it.
Any input greatly appreciated.
Regards, Buster
850 1994 Auto sedan engine miss under load
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Port A6?
https://www.matthewsvolvosite.com/read-codes-volvo-850/
A1 1-1-4 should be sorted out.
It's program selector open or short circuit to supply.
I just saw that your car is '94 850 GLE.
GLE in EU is 10v car...should be in AUS too.
Is it 2.0 or 2.5?
Is it 2.0 or 2.5?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Are the cap and rotor in good shape?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
buster850
- Year and Model: 1994 850 GLE
- Has thanked: 15 times
- Been thanked: 8 times
Hi every one who offered help , today i spent 6 hours with a multi meter and took the time to check the coil, the spark plugs, the crank sensor and the ignition leads. Thank fully I found the problem but it was very hard to spot. Just a pin head dark brown hole in the blue plastic that clips to the spark plug, obviously it was shorting to the block causing weak spark at the plug hence that plug did look darker due to a richer burn from less spark. As a quick diagnostic I wrapped electrical tape around the affected spot and turned the key to find it ran smooth as silk.
I will order new leads as they are the originals from 1994 ! Anyway I am no mechanic, in fact I dislike working on vehicle but by patience and perseverence I got a positive outcome this time.
To answer the other question, the rotor and cap are original 120,000km but Ill keep that in the back of my mind, many thanks to those who responded.
Misha, as for the code I will need to get further information on exactly what slector etc its refering to so Thank you too.
Kind regards Buster.
- Been thanked: 4068 times
Replace the cap rotor and wires as budget allows, Buster. At least clean the brass parts until they are shiny. Use Bougicord for the wires , the other brands cause problems.
Three prong Bosch or Volvo plugs for non turbo cars , single prong ones for turbos
- misha
Is it 10v or 20v?
Ignition cables are not interchangeable between these two engines.
About transmission codes...it could be PNP switch or S,E & W switch on center console.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
I found this out the hard way. I was sent the wrong ones. The ends that fit the plugs on the 10v wires are taller.misha wrote: 07 Jan 2023, 04:02 Is it 10v or 20v?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- misha
If it says DOHC on valve cover...it is 10v.
20v cars have 20v on valve cover.
Is it 2.0 or 2.5?
Is it 2.0 or 2.5?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Buster found his sticker confirming it is a 10V engine in another thread, misha. Take care of those Huskies for us...misha wrote: 08 Jan 2023, 03:21 If it says DOHC on valve cover...it is 10v.
Is it 2.0 or 2.5?
- 2196 Views
Last post by Reys
- 14 Replies
- 2765 Views
Last post by zanzabar
- 605 Views
Last post by vtl
- 1766 Views
Last post by aewoodhouse
- 2331 Views
Last post by HawleyTronics
